what motor oil do you use? (10w30, 5w30, etc)
Re: what motor oil do you use? (4g_civic_si)
I'm using Castrol GTX 10W-30 conventional oil for now while I'm breaking in my rebuilt B18C. I'll be switching over to Mobil 1 synthetic after logging the appropriate number of miles.
Modified by SoichiroH at 7:22 PM 6/30/2003
Re: what motor oil do you use? (SoichiroH)
i have d16y8...what do you recommend? plus im planning to boost...do i need to change to different kind of oil? im currently using 10w30.
Re: (93si)
i would say anything syn i loke mobil 1 the best. but reagular oil if ur pushing ur engine hard and have alot of mods then syn is the way to go for sure . pluss u wouldnt have to change ur oil for alot longer
Re: (gezer)
I use Castrol Syntec 10W30 and before that I used Penzoil 5W30 which is what it came with from the factory. As the motor gained mileage I switched to the 10W30 because it's thicker and better for higher mileage engines. I switched at around 50,000 miles.
ps...there is a ton of info on this site on different oils if you do a search...not bitchen just sayin in case you don't get what you wanted from this thread.
Re: what motor oil do you use? (wantmorepower)
cheapest 20w 50 i can find. I have a 195k mile d16z6 that I am driving on right now until I can justify a 2500 dollar b16 swap.
