NAME this part plz
NAME this part plz
ok the vtec oil pressure sensor bolts into a housing on the back left side of the head RIGHT under the valve cover.. i need the name of that housing... just snapped it off the part the sensor bolts onto trying to tighten the sensor.. it go tto where it should have started tightening... ( not finger tight) and snapped off before it would tighten at all
the housing with the blue cap on ti... sensor bolts into, i brok ethe housing while tightening new sensor on it...
Re: NAME this part plz
d16z6 and is teh vtec solenoid the part that is bolted to the head with the plastic cylinder looking thing pointing up ( i think, mine has a blue metal cap over it). ill edit my post and add a pic
ok i figured out the part... is is the vtec solenoid. now anyone know where i can get a d16 vtec solenoid? been searching a while with no luck
H-T White Ops
I couldn't list them off for you, but I know some VTEC solenoids work for various engines, models and years.
so you might want to look up the part number on a site such as hondapartsdeals.com and then do a Google search or search on here for the part number so you can figure out other cars that use the same one.
ironchef25
03-01-2004 02:50 PM
