Dimming Headlights
Old 02-07-2009, 04:11 PM
MeyekulBayrd's Avatar
Default Dimming Headlights
I couldn't search for this so here's my question.
I have a 00 DX hatch. The problem is the headlights will dim then brighten and they don't do it according to rpm. Any ideas? It's dark so I'm going to check for loose connections tomorrow.
Old 02-07-2009, 04:23 PM
Mr. Badwrench
boostedcivicsir's Avatar
Default Re: Dimming Headlights
start by checking the sockets.
Old 02-07-2009, 04:25 PM
I'm going to borrow a volt meter from work as well. I'm new to Hondas, cars anyhow, and didn't know if it was a common problem. I've been looking through the stickies.
Old 02-07-2009, 04:33 PM
Mr. Badwrench
i know sockets are an issue. usually they build up a little resistence then start to melt.
Old 02-07-2009, 04:34 PM
Thanks. That'll be the first thing I check out in the morning.
Old 02-07-2009, 06:20 PM
CALIGUYCRX's Avatar
Check voltage and loose grounds at times will also either turn the headlight off of dimm , or also could be charging system is failing?
Old 02-07-2009, 06:43 PM
The car just came from Michigan so it may be some salt corrosion. I'm going to check everything though.
Old 02-07-2009, 09:04 PM
SiYouLater's Avatar
Bad alternator?
Old 02-07-2009, 09:16 PM
SOHC_4dr's Avatar
i think you could have a bad alternator. to do a quick check, let your car idle with the lights on and see the voltage at the batt, it should read 14.6v
Old 02-08-2009, 05:34 AM
I forgot that my neighbor is a mechanic. I'm going to pull it in the garage after I drink my coffee and eat some breakfast. My gf said, "It does it everytime the motor moves." Hopefully it's something simple that I can fix today.
Old 02-08-2009, 08:51 AM
Turns out it's the battery not holding the correct charge.
Old 02-08-2009, 01:15 PM
Ok.. Wrong.. Alternator is only putting out 37amp.
Acme_EK_Hatch
06-04-2012 03:00 AM
psyrage19
02-25-2008 04:01 PM
fe519
04-12-2006 11:01 AM
civcexcoupeblack
06-23-2003 04:34 PM
chris408
04-03-2003 10:46 PM
Quick Reply: Dimming Headlights
