what gen is my b16a?
Old 03-31-2014, 08:30 AM
cmaguire613's Avatar
Icon2 what gen is my b16a?
hey im reading that a b16a with the block stamp starting with 5 is the sir 2 and the ones starting with 1 are sir but the sir 2 has hydraulic clutch and obd2 and sir has cable and obd0 however my block stamp is "b16a 11*******" but ive got obd 2 and i have a hydraulic clutch any ideas? also it has no numbers after the a so im told its jdm
Old 03-31-2014, 10:13 AM
carlos8's Avatar
Default Re: what gen is my b16a?
Transmission and sensors isn't the way to I.D. an engine, the most reliable is the head stamp.
http://www.ff-squad.com/tech/head/bs...arofhead_2.jpg
This tell you the year of the cast made, and by the year look to what generation belong your engine.
Old 04-07-2014, 05:02 PM
alright where will i be able to find out what gen via the stamp number?
Old 04-07-2014, 05:04 PM
KiNGDEE206's Avatar
Look at the head, right above the header
take a pic of your head similar to this pic:
Old 04-07-2014, 05:14 PM
the visible stamp says
b16a
1017572
oh ty ill check it
Old 04-07-2014, 05:20 PM
says 89 so da6 or da8 if im correct 160 hp stock at crank
Old 04-07-2014, 05:22 PM
and dohc is larger then tvech on my valve cover
Old 04-07-2014, 05:24 PM
carlos8's Avatar
Yes, this is crx, siR and xsi 89-91 jdm b16a head.
VTEC
No double valve springs and lousy cams!!!
Old 04-07-2014, 07:17 PM
Crazy Honda Guy
Deetz's Avatar
VTEC
If the engine is a 1st gen b16, it would have made 160hp, and yes, it would have had dual valve springs. They would have been 1st gen cams that were a bit mild, but with today's prices on used cams, that can be fixed easily.
"If", the 1st gen b16 was an auto, then yes, it would have been the weakest of all b16's with single valve springs and mild cams....I think only 150hp if memory serves right
Old 04-08-2014, 11:54 AM
cool so i should upgrade cams and springs ? while im at it is it worth it to just fully build the head?
TrueEm1
18
06-26-2016 04:04 PM
WONG FRIED RICE
05-19-2014 06:21 AM
DTS
09-19-2006 07:49 PM
T_Rex
09-07-2002 10:04 AM
Quick Reply: what gen is my b16a?
