what is a fail safe relay? HELP - Honda-Tech
Old 10-05-2006, 12:39 PM   #1
Speed_69's Avatar
Default what is a fail safe relay? HELP
so i brought in my civic to a honda dealership a few weeks ago to scan my ABS codes because my ABS light was on . One of the codes came up 'battery voltage failure' and my two rear speed sensors were failing. I was told that it was unusual for both speed sensors to fail at the same time so they told me to replace the battery and that should resolve the problem. So i replaced the battery on friday and thought all was good because the abs light went out but yesterday on my drive to school, it appeared again. Now, the abs light keeps going on sometimes and then it goes off sometimes.
These were the following ABS CODES:
61-01 Battery Voltage Failure
54-01 Fail-safe Relay Failure
15-01 Right rear wheel speed sensor open shot
16-01 Right rear wheel speed sensor failure
18-01 Left rear wheel speed sensor failure
so i'm just wondering what the Fail-safe relay is? and where is it?
and if anyone can help me with my problem..thanks!
Speed_69 is offline   Reply With Quote
Old 10-06-2006, 12:25 AM   #2
Speed_69's Avatar
Someone help please!!
Old 10-06-2006, 01:30 AM   #3
HT White Ops
Here you go man, straight from the Service/ETM:
Eran is offline   Reply With Quote
Holly ABS Codes- HELP!!! forbes march Honda Accord & Crosstour (2003 - Current) 6 08-19-2013 10:50 AM
ABS codes pulled friutoftheLude Honda Prelude 12 02-25-2013 09:33 AM
SRS and ABS Codes Solster Honda Civic / Del Sol (1992 - 2000) 8 01-28-2009 08:42 AM
ABS code 6-1 help please arejaygsx Acura Integra 3 01-30-2007 06:56 PM
Help: ABS Light on Speed_69 Honda Civic / Del Sol (1992 - 2000) 3 10-06-2006 02:31 PM
Tags
1801, 5401, abs, accord, civic, codes, crv, fail, failsafe, failure, honda, prelude, rear, relay, safe
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
