what ecu can i use to pass smog ?
im returning my 97 civic back to stock . im taking my B16 and putting a D16Y8 from a 97 civic back in .
what ECU can i use in order to pass smog ?
does it have to be 96-98 EX or can it be 99-00 EX as well ?
my smog is do in 2 weeks and i have to pass smog .
thanks.
thanks.
Re: what ecu can i use to pass smog ? (green eg in tha LBC)
ok so if the engine is a 97 EX, does it have to be a97 EX ecu or can it be a 96-98 EX ecu ?
as long as its an EX and 96-98 right ?
thanks by the way.
thanks by the way.
Re: what ecu can i use to pass smog ? (twisted_jdm_b16)
It needs to be a 96-98 Ex ECU because that ECU plugs directly into your 97 Civic without a conversion harness. Should you have choosen to go with a 99-00 Ex ECU, the story wouldn't be the same.
So just get a 96-98 Ex ECU and that should do it...but it's still no gauruntee unless your Civic is also an Ex and even then it's not a gauruntee. For example, not all 96-98 hatchbacks came with a FTP sensor but (I'm pretty sure) all 96-00 Ex's did come with one. So if that's the case, you're screwed unless you want to fit that sensor and the related plumbing into your non-Ex Civic.
1 Post
Re: what ecu can i use to pass smog ? (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris »</TD></TR><TR><TD CLASS="quote">It needs to be a 96-98 Ex ECU because that ECU plugs directly into your 97 Civic without a conversion harness. Should you have choosen to go with a 99-00 Ex ECU, the story wouldn't be the same.
So just get a 96-98 Ex ECU and that should do it...but it's still no gauruntee unless your Civic is also an Ex and even then it's not a gauruntee. For example, not all 96-98 hatchbacks came with a FTP sensor but (I'm pretty sure) all 96-00 Ex's did come with one. So if that's the case, you're screwed unless you want to fit that sensor and the related plumbing into your non-Ex Civic.</TD></TR></TABLE>
to be 100% positive you have the right one, you need a P2P-A33(2dr) or P2P-A03(4dr). (printed on label on side of case)
logically you could switch the two but I'm not sure.
FYI there are 33 different versions of the P2P out there.
Re: (Relic1)
yeah i know there are many diffrent variations for the P2P out there .
well i do know that im currently running a P73 ecu with my B16 setup and i beleive we did use the stock EX harness.
am i right . the p73 harness is the same as the harness or the D16Y8 ?
the cars a Ex 97 coupe.
Re: (sicones)
well actually im goin to be selling the coupe as well . im thinking of getting a ek hatch . i want to throw the d16 in there , pass the smog and sell it .
i still need the stock exhaust manifold ,injectors ,ecu , and axels to complete the d16 swap .
any suggestions on where should i be oooking to get these parts and around how much it would run me for them ?
