what does the iat sensor do? - Honda-Tech
Old 05-04-2005, 09:02 PM   #1
civic_tuned's Avatar
Default what does the iat sensor do?
today i was checking my sensors because i had a fluncuating idle and my engine does a sort of stall and sputters. i replaced the tps sensor and put it to specs. I cleaned the iacv. I checked the map and the iat. The map is working fine except the iat. i checked it with voltmeter at 20dc's and it gave a 1.89-2.00. Is this bad? I want to make sure i checked it right. I tapped the + needle to the red wire and the -needle to the green wire. I checked my haynes book and it said that the voltage should be between 3.5-5.5 is this correct or am i wrong. Here it goes with my stupid ? what does the iat do?
civic_tuned is offline   Reply With Quote
Old 05-04-2005, 09:12 PM   #2
H-T White Ops
Frozen E's Avatar
Default Re: what does the iat sensor do? (civic_type_r)
senses intake air temp?
Frozen E is offline   Reply With Quote
Old 05-04-2005, 09:17 PM   #3
Default Re: what does the iat sensor do? (IslandSi)
Quote:
i guess
Old 05-04-2005, 09:48 PM   #4
c'mon guys!
Old 05-05-2005, 06:55 AM   #5
EE_Chris's Avatar
The IAT tells the ECU how hot the coolant is...duh.
C'mon now - IAT - intake air temperature - not that hard. Because Honda's use a Speed-Denisty type of fuel injection system, the volume of air entering the engine is not directly measured, as it is in a MAF based car. The temp of the air must be known to calculate this volume.
Temp/Voltage:
60*/3.35v
70*/3.08v
80*/2.81v
You can also use the ECT sensor as a reference value to compare to the IAT when the engine has been allowed to sit overnight. They share the same output characteristics.
EE_Chris is offline   Reply With Quote
a few code/sesnor q's about h22 reesezrex Tech / Misc 6 05-01-2012 05:25 PM
IAT error code on Hondata S300b laopadak303 Forced Induction 3 11-08-2011 01:56 PM
partial throttle idle up and down and IAT sensor code question jdmshawn95 Honda Civic / Del Sol (1992 - 2000) 0 10-07-2011 09:22 PM
IAT sensor kenny24 All Motor / Naturally Aspirated 4 11-09-2005 11:58 PM
Installed ITR manifold, IAT question JMinSi2000 Forced Induction 2 11-11-2004 09:55 AM
Tags
abad, air, characteristics, civic, do, h22, honda, iai, iat, intake, sensor, temp, temperature, voltmeter, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
