What does a bad cv joint sound like
Old 04-13-2004, 07:19 PM
jerm001's Avatar
Default What does a bad cv joint sound like
I have this weird noise coming from somewhere in front of my car, can't tell where, I'm sort of leaning towards the right side though. Anyways, it only occurs at a certain rpm (no tach) when accelerating fast it isn't there, and when driving not accelerating at all it isn't there either. Doesn't occur when the clutch is in, or when it is in nuetruel only when driving.
if any one has any clue what this sound may be please let me Know
P.S I bought that belt dressing stuff and sprayed it on the alternater belt and the noise is still there
Thanks again
Old 04-13-2004, 07:20 PM
Convoy's Avatar
Default Re: What does a bad cv joint sound like (jerm001)
does it make noes when u turn??
Old 04-13-2004, 07:27 PM
jerm001's Avatar
no, no noise when you turn
Old 04-14-2004, 09:21 AM
jerm001's Avatar
Could it possible be a heat sheild rattle?
Old 04-14-2004, 09:30 AM
96hb's Avatar
Default Re: (jerm001)
*click* *click* *click* *click* *click* *click* *click* *click* when you go around turns. Get under there and see if you have a ripped boot. If you do, you might as well change the axles because dirt and other debris has already gotten in there.
Old 04-14-2004, 09:49 AM
Phatch99's Avatar
Default Re: (96hb)
Don't mean to jack your thread but what if click,click,click,click after new axles installed??
Old 04-14-2004, 09:53 AM
Filliam H. Muffman's Avatar
Default Re: (Phatch99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phatch99 &raquo;</TD></TR><TR><TD CLASS="quote">Don't mean to jack your thread but what if click,click,click,click after new axles installed??</TD></TR></TABLE>
then you got bad axles
its either that or the guy holding you up for your new axles has no bullets in his gun
Old 04-14-2004, 10:30 AM
ABK
ABK's Avatar
Default Re: (JUN EK9)
maybe your other axle is messed up too
and you need to replace it
Old 04-14-2004, 10:47 AM
GSR-Civic's Avatar
take the heat shield off and see what happends
Old 04-14-2004, 11:09 AM
assman_91's Avatar
Default Re: (GSR-Civic)
check if your cv boot is torn...is there grease all inside your wheel?
a bad cv usually clicks
Old 04-14-2004, 12:18 PM
jerm001's Avatar
ok, Its definitly not the cv joint then, the sound is a sort of rattle, (sounds are so hard to describe)
Old 04-14-2004, 12:21 PM
96hb's Avatar
It could be the heatshield near your cat. That thing rattled like a **** on my last car.
Old 04-14-2004, 12:24 PM
lohatch's Avatar
perhaps it is something in your tranny clicking since it is coming from the front of your car. if your were in the drivers seat it would appear to be coming from the right side, and it is only occuring when in gear and doesnt happen when turning corners ruling out the CV joint. maybe a body panel in the front right is causing some vibration, or anything up there could be lose making noise. get in there and check it out
Old 04-14-2004, 12:31 PM
jerm001's Avatar
when in the drivers seat I think its coming from the left
Bushera
11-21-2012 10:01 PM
simplypinoyy
08-06-2008 09:17 AM
f22 lx
08-11-2006 11:25 AM
civic nut
04-14-2005 01:28 PM
Steveo92'vx
09-01-2003 09:38 PM
Quick Reply: What does a bad cv joint sound like
