what do i need to do to my b16a2 to turbo it??
whats up guys im new in this so i need some help and so suggestions on what to do to turbo my b16a2.
ok this is what i have done to the engine right now:
the head is fully built with skunk2 stage 2 cams,cam gears,valves,valve springs,lifters,intake Manifold,240cc injectors and everything else.the bottom end is completely stock with b16 hydro spoon lsd with a 6 puck stage 2 clutch. i have a AEM fuel rail fuel regulator and fuel gauge.
thanks for viewing this!!
get the turbo, intercooler, intercooler pipeing, wastegate, Fuel management unit, Fuel Pump, fuel injectors, Missing Link, B Series Turbo Exhaust Manifold, Steel Breaded Oil Line, Oil Return Line, Down Pipe, And A Blow Off Valve, The Rest is just Vaccume lines and Bolts Ect. Flange
This Site can help you out with the install it show full install for the Turbo
http://www.maxrev.de/complete-...8.htm
Almost Forgot The MSD- Multi spark Dentinator Helps with high voltage Arc To your Sparkplugs
Gap Spark Plugs to .030- NGK part # BCPR7ES-11 are preferred.
Re: what do i need to do to my b16a2 to turbo it?? (92civicx)
i want to be able to push from 10 to 15 pounds of boost.
let me know if there is something else i should think about.thanks
Re: what do i need to do to my b16a2 to turbo it?? (b16motor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16motor »</TD></TR><TR><TD CLASS="quote">i want to be able to push from 10 to 15 pounds of boost.
With what size turbo?
Re: what do i need to do to my b16a2 to turbo it?? (I heart my Honda.)
I've got a KKK k-26 turbo just sitting around my room if your interested? Set up for external wastegate. Just inspected as "like new". Spins free with no problem. Just let me know....
DR. ON POINT
06-27-2001 06:25 PM
