What to do with 3k?
What to do with 3k?
I want to put 3k into my 98 civic ex i was thinking a greddy turbo set up or a CTR engine. WHat do you guys think?
Re: What to do with 3k? (ramz7887)
Stock. I want a swap or a turbo set up. I would like to find a swap that allready has a turbo and have the best of both worlds.
This august. I'm going to college and every semester i get about 2000 or so left over to spend on my baby
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramz7887 »</TD></TR><TR><TD CLASS="quote">Stock. I want a swap or a turbo set up. I would like to find a swap that allready has a turbo and have the best of both worlds.</TD></TR></TABLE>
well, i would tell you to fix that stuff first. but if you want power, you will have a very very very hard time finding a swap with a turbo for that price.
greddy or apexi turbo kit
at the jetties fishin'
buy a b16a2 swap from http://www.importautosalvage.com for $2500 shipped with everything needed to bolt it all in...
then, part out your engine, old harness, ecu on ebay and along with your extra $500 use it to get a T3 manifold, a T3 turbo, and a v-afc to start your turbo kit along by getting the big three out of the way....
or get a few big tittied hookers for the weekend
Re: What to do with 3k? (jwn7)
yeah i thaught that would be the case. I like the ITR engine but its goes for 45xx plus another 750 for install. THats too much. The reason why i was considering a swap is because my d16 has 110xxx miles. But i know that miles don't mean anything as long as the compression is good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 »</TD></TR><TR><TD CLASS="quote">
greddy or apexi turbo kit </TD></TR></TABLE>
Re: What to do with 3k? (stackz)
I can pass on the hookers. What do you think i could get for my d16y8 with an aem short ram and a dc sports 4-1 ceramic header. I also just had the timing belt changed/water pump and the valves adjusted.
you'd make more parting it out.
sell the head without the distributor but with the harness and ecu and you'll get about $300-350 for it on the bay...
toss the aem up for about $50-75
the dc header will bring about $75-125
pistons/rods will net probably $50
crank will get $100
block if you can ship freight...will be about $200
and the aluminum oil pan will be another $50
the distributor should get you about $100
or try to sell the engine whole locally for $500
crank will get $100
Mr. Badwrench
Re: (corgiat)
get a house forst. i did and glad i did then worked my car. my o.o2. take it from an old head. if not, maybe a gsr then boost, or maybe brakes and suspension to handle a swap later?
nogi
09-18-2007 06:57 AM
