What direction does the crankshaft pulley bolt turn to loosen ? (d15b2) - Honda-Tech
Old 04-27-2008, 10:17 PM   #1
demomano's Avatar
Default What direction does the crankshaft pulley bolt turn to loosen ? (d15b2)
Thank you.
demomano is offline   Reply With Quote
Old 04-27-2008, 10:56 PM   #2
Neebs's Avatar
Default Re: What direction does the crankshaft pulley bolt turn to loosen ? (demomano)
Should be right hand threaded. Counter-clock wise.
Neebs is offline   Reply With Quote
Old 04-27-2008, 11:04 PM   #3
zero708970's Avatar
easiest way to take the pulley off (for me at least) is to take off the starter and get something caught in the flywheel and have someone else undo the bolt. word of caution though you could mess up one of the teeth oh, and that thing is on TIGHT! I got it off with a 5 foot pipe as a breaker bar and it still took us a while.
zero708970 is offline   Reply With Quote
Old 04-27-2008, 11:58 PM   #4
demomano's Avatar
Default Re: What direction does the crankshaft pulley bolt turn to loosen ? (zero708970)
Thanks....
tried to block the engine with gear and brakes on but clutch seems to slip when turning off with a breaker bar
going to try with pneumo tool...
Old 04-28-2008, 12:05 AM   #5
demomano's Avatar
also heard that there is special tool used to block engine that fits into hexagonal socket of the pulley and it has a hole to put a socket on pulley bolt...
Crankshaft pulley bolt - 98 CR-V ryan67203 Honda Element & CR-V 2 11-14-2016 07:16 PM
Quick Question guys.. WyKi Tech / Misc 2 01-10-2007 11:48 AM
turning crankshaft david90 Honda Accord (1990 - 2002) 6 08-20-2003 09:47 PM
crankshaft pulley bolt? Sephro Honda Prelude 16 04-03-2003 07:59 PM
Which way to turn the crank pulley bolt?!?!?!? youngkow Hybrid / Engine Swaps 12 11-22-2002 02:21 AM
Tags
2000, 91, bolt, civic, crank, crankshaft, direction, honda, integra, loosening, odyssey, pulley, shaft, thread, turn
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
