what the difference between the p28 and p72 ecu
i have a gsr swap with obd2 rite now
but i want to go to obd1 are there any difference between these two after i chip with some type or program becuase the p28 is so much cheaper then the p72
Re: what the difference between the p28 and p72 ecu (u2civic1)
it all depends on the chip. if you use two identical chips on a p72 and a p28, it will run the same. it will run off of the program on the chip.
Re: what the difference between the p28 and p72 ecu (Steady)
p28 cant run knock or iab
spend the extra coin and get the p72
I have a chipped p72 and the only real advantage is I can remove the little jumper pin to unchip the ecu and it will run off of the stock ecu program. I only do this when I am running my stock intake manifold.
Jdmlifetyper
03-26-2012 11:35 PM
MOVE OVER
09-06-2007 08:59 AM
ilovejdmhoes23
01-20-2007 11:52 PM
