What can you use to remove a stuck spark plug?
Old 01-09-2004, 01:30 PM
Campee's Avatar
Default What can you use to remove a stuck spark plug?
Can you use penetrating fluid, WD40, etc to remove a spark plug that the previous owner jammed in too hard and now won't come out? Or does anyone have any other suggestion for what to use?
Old 01-09-2004, 02:05 PM
chads's Avatar
Default Re: What can you use to remove a stuck spark plug? (Campee)
it sounds like it was cross threaded. if so i don't know how to fix it but im sure its very expensive.
Old 01-09-2004, 02:06 PM
Solbros Owns Me
Evs-One's Avatar
Default Re: What can you use to remove a stuck spark plug? (FlamencoEsi)
just use a breaker bar...
worst case scenerio you have to pull the head and drill it out
Old 01-09-2004, 03:56 PM
Campee's Avatar
Default Re: What can you use to remove a stuck spark plug? (Emerika)
Well, it's not frozen... it's just really hard to remove and I wanted to knock it loose w/ something first.. thought I could have used one of the liquids i mentioned earlier. Are those cool to use or no?
Old 01-09-2004, 03:58 PM
Solbros Owns Me
Evs-One's Avatar
it's fine if you use those those liquids...sure
Old 01-09-2004, 05:30 PM
BrockGrimes's Avatar
I've used a couple drops of 10w/30 to help out a tuff plug.
On a side note if you get one thats stuck, stick a piece of dry ice on the plug, it shrinks the metal in the plug and helps loosen it up.
Old 01-09-2004, 06:07 PM
lohatch's Avatar
they make anti-seize stuff to put on your plugs so they dont stick for future reference. hopefully your threads arent screwed up....
pityocamptes
09-10-2015 09:55 PM
salaamq
12-28-2011 09:59 PM
sacalait59
04-25-2010 02:52 PM
91accordex16
06-24-2005 06:13 PM
B_CRUZ!
02-14-2002 08:45 AM
Quick Reply: What can you use to remove a stuck spark plug?
