What is the best grease to use on a window regulator?
I'm removing the old grease and putting new grease on a used window regulator I bought.
I'm replacing the grease on the "scissor's" teeth and also the grease inside the window motor's gear box. I believe white lithium grease is supposed to be used for everything but the old grease doesn't look like white lithium grease.
So should I use white lithium grease for everything or are there other greases I should use?
Would white lithium grease be ok for the rubber o-ring seals in the gear box?
Re: What is the best grease to use on a window regulator?
Have you also used it in the window motor gear box? I'm worried it might not be good for the rubber seals.
Honda sells some stuff that comes in a black and green can that works hella good its a spray and makes it way easier to use
graveltravel2
11
02-21-2007 03:43 AM
