iac valve
Old 10-20-2006, 04:45 PM
thollis97's Avatar
Default iac valve
I think i have the two vaccum hoses mixed up on the iac valve and need no where they come from or go.
Old 10-20-2006, 04:55 PM
Heretic:Si's Avatar
Default Re: iac valve (thollis97)
the hoses that go on there have coolant/antifreeze in them, they're not vacuum lines. they should go on and look straight when on. if i mixed mine up on my car they would look kinked. hope that helps.
Old 10-20-2006, 05:11 PM
thollis97's Avatar
Default Re: iac valve (Heretic:Si)
do you know where they come from
Old 10-20-2006, 05:19 PM
Heretic:Si's Avatar
if you're looking at the motor the line on the left comes from the sensor under the throttle body which comes off the head. the one on the right is from the water pipe.
Old 10-21-2006, 01:37 PM
thollis97's Avatar
Thanks. i found the problem.
Old 10-21-2006, 04:05 PM
Heretic:Si's Avatar
no problem
LSej1
Honda Civic (2001 - 2005)
09-04-2017 09:45 PM
Dekorum
10-15-2013 01:45 PM
89 civic si
09-26-2006 08:17 AM
mingbling
03-21-2004 06:12 PM
GSRwBOOST
01-12-2002 06:47 PM
Quick Reply: iac valve
