vtec solenoid
Old 11-13-2006, 11:52 PM
20CiViCSi00's Avatar
Default vtec solenoid
i have a b16a2 and i need a new vtec solenoid , my question is will a sohc vtec solenoid work or does it have to be bseries ?
Old 11-14-2006, 12:35 AM
Pr0ject93hb's Avatar
Default Re: vtec solenoid (20CiViCSi00)
correct me if im wrong but it needs to be a b-series. im pretty sure at least
Old 11-14-2006, 06:06 AM
Technical Hero
HondaPartsHero's Avatar
Default Re: vtec solenoid (Pr0ject93hb)
it'll work
Old 11-14-2006, 06:47 AM
eg-owns you's Avatar
im pretty sure it needs to be a B
Old 11-14-2006, 07:58 AM
MidwestSiR's Avatar
it'll work, but the vtec oil pressure switch will be pointing towards the fromt of the car.
the solenoid only controls the oil passage to activate vtec nothing else..
there are no differences between the two, the pressure switch is also the same. vtec engagement is entirely dependent upon outside electronic control via the ecu and/or any piggybacks you might have.
Old 11-14-2006, 08:31 AM
...Baker's Avatar
Default Re: (MidwestSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestSiR &raquo;</TD></TR><TR><TD CLASS="quote">it'll work, but the vtec oil pressure switch will be pointing towards the fromt of the car.
there are no differences between the two, the pressure switch is also the same. vtec engagement is entirely dependent upon outside electronic control via the ecu and/or any piggybacks you might have. </TD></TR></TABLE>
yup, it'll work
lol @ midwestsir for losing his password
Old 11-14-2006, 10:24 AM
Default Re: (.:Baker:.)
thanx for the replies ill pick that up from my friend , im tired of not having vtec engagement , damn code p1259!!!
Old 11-14-2006, 11:52 AM
Default Re: (20CiViCSi00)
o and one more thing , my boy also has an ls im . would i get any better numbers with that or should i stay with the stock untill i get a sunk2 or something
Old 11-14-2006, 12:45 PM
Technical Hero
LS won't fit on a b16 without modifications
Old 11-14-2006, 02:38 PM
2to5coupe
Guest
Posts: n/a
they work just fine but b16 and h22 have bigger ports than gsr4, sohc vtec and the b16A3
MyIntegra
06-12-2009 10:54 AM
Tunerguy1989
05-05-2009 02:54 PM
5280dc2
04-06-2008 07:53 AM
frye-eghatch
11-25-2005 03:02 PM
Quick Reply: vtec solenoid
