vtec pressure switch??????????
Old 08-26-2006, 10:45 AM
nutball72's Avatar
Default vtec pressure switch??????????
did a d16 mini me put a fairly new vtec solenoid and wired it decently. i get code 22 for vtec pressure switch what is that? also when wiring i just fished the wires through the wire harness at the ecu instead of putting some kind of clip, does anyone know what size clip and what kind to use for the ecu?
Old 08-26-2006, 10:54 AM
happyabortion's Avatar
Default Re: vtec pressure switch?????????? (nutball72)
vtec pressure swith is the two wire plug the the solenoid. check what ground you used and make sure that wire is touching right on the ecu
tofastgsr
Engine Management and Tuning
10-26-2012 06:11 AM
sharkcohen
03-11-2005 07:55 AM
KY
12-22-2004 05:46 PM
eg6T
11-07-2004 06:20 PM
RS Design
04-10-2004 11:16 PM
Quick Reply: vtec pressure switch??????????
