vtec oil pressure switch connector
Old 12-13-2009, 05:40 PM
Kaleb's Avatar
Default vtec oil pressure switch connector
I need a vtec oil pressure switch female connector. Does anyone know where one can be ordered? I have been searching for awhile but no luck.
Old 12-13-2009, 06:32 PM
vtechjunkie's Avatar
Default Re: vtec oil pressure switch connector
You can also get the JDM solenoid to get rid of the switch, or just not plug it in and delete it from your ecu. Just some alternative ideas for you to ponder.
Old 12-13-2009, 06:36 PM
Jackal6042's Avatar
Good luck on finding where to purchase just the clip new. I've been building Hondas for a decade and am a wiring guru... I've never successfully found anywhere to order these clips or even the wiring pins. What I've always done is cannibalized them from old wiring harnesses since the only way to get them from Honda is to order the whole harness its attached to.
I happen to have a few spares of the pressure switch clip you are looking for with the pins and about 3" of wire pigtail on them. If you're interested PM me and we can work something out I'm sure.
Old 12-13-2009, 06:45 PM
Kaleb's Avatar
It is a jdm engine, it's a b16a.
Old 12-13-2009, 06:55 PM
Well then, how does people like Ryan @ Rywire get the pins for his harnesses? You can buy the pins somewhere I'm sure.
Old 12-13-2009, 06:56 PM
It must be a USDM solenoid then.
Old 12-13-2009, 06:59 PM
Anon51's Avatar
actually he requires you to send in your harness for most of it or he finds one he's got laying around.
Old 12-13-2009, 07:13 PM
redbull-1's Avatar
You can buy terminal pin kits from Honda; but, they are not cheap.
Some pin kit numbers 07JAZ-003000B, 07QAZ-003020B to name a few, and there are others.
Old 12-16-2009, 03:56 PM
Jackal6042's Avatar
Yeah the kits are bad ***, they have the little rubber plugs for the under-hood wiring and everything. But its a pretty expensive kit as you mentioned, I think about $400 each. **** that, I just clip harnesses of salvage **** and pull the pins with a few inch pig tail.
Delphince
Engine Management and Tuning
23
06-08-2018 05:18 AM
xChrizcrozzx
07-30-2015 08:35 AM
barone
25
08-20-2009 08:32 AM
FlyingDaggers
11-09-2007 11:48 AM
GummyBeng
02-17-2003 08:18 AM
Quick Reply: vtec oil pressure switch connector
