valve cover paint? - Honda-Tech
valve cover paint?
Old 04-11-2012, 03:01 PM   #1
lilboxx's Avatar
Default valve cover paint?
does anyone know of a good paint to use on valve covers? one that will last and not chip off after a month
lilboxx is offline   Reply With Quote
Old 04-11-2012, 03:05 PM   #2
DELshaneSOL's Avatar
Default Re: valve cover paint?
Use heat paint of some kind If you do it right and prep real good it won't chip
DELshaneSOL is offline   Reply With Quote
Old 04-11-2012, 03:06 PM   #3
Global Moderator
Jimmy's Avatar
VHT wrinkle black or red.. should be able to google it.
Jimmy is offline   Reply With Quote
Old 04-11-2012, 03:08 PM   #4
EH2Kevin's Avatar
Quote:
EH2Kevin is offline   Reply With Quote
Old 04-11-2012, 03:24 PM   #5
I use that metallic high heat paint in the spray can from advance Auto parts works like a charm just make sure I sand it good and prime it before using the color paint
dunkingmofo is offline   Reply With Quote
Old 04-13-2012, 02:30 PM   #6
i used red high temp brake caliper paint on my valve cover, been painted for 6 months or so and no chips or weird deformations
Andrewzabomb is offline   Reply With Quote
Old 04-13-2012, 02:56 PM   #7
KINGVEM^^ED6's Avatar
Krylon paint hasn't chipped I cleared it too
KINGVEM^^ED6 is offline   Reply With Quote
Old 04-13-2012, 03:37 PM   #8
Crazy Honda Guy
Deetz's Avatar
Here's a shot of how VHT wrinkle comes out
Deetz is offline   Reply With Quote
Old 04-13-2012, 03:44 PM   #9
did u get ALL the old paint off and prime it?
Old 04-13-2012, 03:55 PM   #10
Ive always been a fan of powder coat, but really any type of paint is usable, as long as you prep the right way.
AReynolds91 is offline   Reply With Quote
Old 04-13-2012, 04:27 PM   #11
Crazy Honda Guy
Deetz's Avatar
^^ This is how my powder coated valve cover came out, back in the day
Old 04-13-2012, 04:33 PM   #12
EH2Kevin's Avatar
Quote:
This looks awesome.
Old 04-13-2012, 04:44 PM   #13
spAdam's Avatar
Quote:
Powder coat IS awesome. But for the investment of a can of VHT and a can of Tal-Strip I can get really good results four times before I equal the cost of taking it to a powder coater once.
spAdam is offline   Reply With Quote
Old 04-13-2012, 05:43 PM   #14
This what my valve cover and intake pipe look like with the right prep and VHT paint from advance.
Old 04-13-2012, 06:59 PM   #15
brake caliper paint
Old 04-13-2012, 07:03 PM   #16
EK9
Dc4LsTeG's Avatar
Anyone using regular spray paint and adding clear coat?
Dc4LsTeG is offline   Reply With Quote
Old 04-13-2012, 07:17 PM   #17
Quote:
You should use high temp, not just regular spray. Engine bay temps will maul regular spray real quick.
jbpnoman is offline   Reply With Quote
Old 04-13-2012, 07:25 PM   #18
EK9
Dc4LsTeG's Avatar
Even with a high temp clear?
Old 04-13-2012, 07:30 PM   #19
spAdam's Avatar
Tal-Strip, mask, acetone, VHT, bake. Came out perfect.
Old 04-13-2012, 09:49 PM   #20
Arthas's Avatar
Nothing but powder coat touches any of my valve covers.
http://honda-tech.com/showthread.php?t=2672726
Valve cover fashion tips
Arthas is offline   Reply With Quote
Old 04-14-2012, 03:59 AM   #21
Yes. Different chemical compositions to the paint.
Personal opinion: Powder coating is a waste of money, and a played out scene. If I'm showing off my valve cover, I'd rather show off the time and effort I put into painting it than show off how much I can spend on having someone else do it for me.
Old 04-14-2012, 05:52 AM   #22
bgguyshatch's Avatar
Sorry but the wrinkle is nasty just use highroad temp engine paint just make sure.its preped right and you'll have no problems
bgguyshatch is offline   Reply With Quote
Old 04-14-2012, 09:24 AM   #23
gzes's Avatar
srry to thread jack but would the spark plug cover on b16 be bad to have plastic dipped black? I mean its plastic and I don't think it'd get nasty... I painted mine with the plastic dip. Still have to get engine to run then I will see what happens lol
gzes is offline   Reply With Quote
Old 04-14-2012, 09:49 AM   #24
hannslebo's Avatar
This is my last car....I used paint thinner to get off the crinkle3 .
Not really a fan of the crinkle.
Then sanded a bit and used some regular ol rust oleum to paint.
I did 3 coats with the white rust oleum and then applied 2 coats of clear.
I think it turned out pretty good.
hannslebo is offline   Reply With Quote
Old 04-14-2012, 10:39 AM   #25
spAdam's Avatar
Quote:
Ehh its a matter of opinion, I personally don't care for valve covers that aren't a stock color. But yes, it can't be restated enough... the prep is the most important part.
Custom painted valve covers. 93 Eg Couper Honda / Acura 3 07-10-2009 01:15 AM
WTB:Painted valve cover ChiLS Want to Buy 5 08-19-2008 10:13 AM
WTB: GSR valve cover Htounndea Southern California (Sales) 2 02-16-2007 06:58 PM
caliper paint on valve cover? diesel1245 Acura Integra 1 03-12-2006 07:22 AM
red valve cover paint. hondatuner20 Honda / Acura 10 12-31-2005 10:23 PM
Tags
1994, 1997, black, civic, cover, green, honda, hondatech, paint, spray, type, valve, valvecover, vavle, wirnkle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
