Urgent! 93 Civic EX Power Window wiring diagram passenger side! - Honda-Tech
Old 12-13-2007, 12:58 PM   #1
Essenar83's Avatar
Default Urgent! 93 Civic EX Power Window wiring diagram passenger side!
My power window switch is f***ed, it only rolls down. I forgot to unplug the switch and my friend rolled it down and when I told him it didn't work, he kept trying to roll it up and in the process rolled it ALL the way down.
Now, I know it's the ground wire for the up switch that's messed up and the switch is INDEED broken. I need to know the ground wire for the down switch and the up switch so I can tap into it to make it "somewhat" work so I can roll that **** up and unplug it again.
I know this isn't a good fix, but it's temp. I need to get the power window passenger switch.
Essenar83 is offline   Reply With Quote
Old 12-13-2007, 01:51 PM   #2
Relic1's Avatar
easiest way to roll up a power window when the switch is screwed up...
tap into the two window motor wires, connect one to 12V the other to ground.
if window tries to go down, switch the wires.
Relic1 is offline   Reply With Quote
Old 12-13-2007, 11:01 PM   #3
Essenar83's Avatar
Okay that's great but how do I know which one is 12v and which one is ground?
Old 12-14-2007, 07:35 AM   #4
Relic1's Avatar
try it one way, then<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">if window tries to go down, switch the wires.</TD></TR></TABLE>
you're not going to to damage the motor if you only hold the power to it for a second or two. (and it doesn't move)
Window rolls up but not down? Azavala Honda Civic / Del Sol (1992 - 2000) 11 08-02-2016 12:08 PM
96 Civic EX Passenger Side Window ONLY Rolls Down Not Up jermo Honda Civic / Del Sol (1992 - 2000) 8 04-24-2016 08:56 PM
1997 Accord Coupe Pass window wont roll up from either switch pre90 Honda Accord (1990 - 2002) 1 06-09-2015 11:22 AM
power window problem '97 civic EX sedan DelSolDon Tech / Misc 8 10-09-2010 10:53 AM
need help, power window not working... PlikityPLAH Acura Integra Type-R 4 11-15-2003 04:28 PM
Tags
92, 93, 96, civic, diagram, honda, passenger, power, schematic, schmatic, stereo, switch, window, windows, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
