UNDER DASH FUSE BOX LABEL - Honda-Tech
Old 08-08-2004, 07:34 AM   #1
Honda-Tech Platinum Member
Setsuna F Seiei's Avatar
Default UNDER DASH FUSE BOX LABEL
My car: 1999 EJ6/EK CX
I just noticed that the under dash fuse box clear label is missing. I SEARCHED and came across this:
I confirmed that's this diagram is for EK owners but the question is whether there would be a difference between DX/CX fuse locations since the CX lacks some of the DX's accessories.
2nd question, basically I'm trying to wire the white illumination wire on my tachometer, but I don't have a dimmer switch in my CX so I'm trying to wire it to the instrument lights since I only want the tachometer to light up when my instrument cluster is on along with either the low and high beams. Would the wires coming out of the instrument light fuse towards the instrument cluster be the right wire to tap into if I want that setup? What difference would this make if I wire it to a dimmer switch?
Setsuna F Seiei is offline   Reply With Quote
Old 08-08-2004, 08:12 AM   #2
Default Re: UNDER DASH FUSE BOX LABEL (BrokeAssPinoy)
help anyone?!
Old 08-08-2004, 09:17 AM   #3
CivicSiRX's Avatar
all the same.
CivicSiRX is offline   Reply With Quote
Old 08-08-2004, 02:27 PM   #4
Default Re: (CivicSiRX)
So it's the same for CX/DX?
How about soem answer to this question:
Old 08-08-2004, 07:52 PM   #5
dsowers19's Avatar
Default Re: (BrokeAssPinoy)
just plug the positive wire into the fuse box where the instrument lights fuse is and then plug the fuse back in, then all you have to do is ground the negative wire. I did this with my light up gauges and it works great.
dsowers19 is offline   Reply With Quote
Instrument lights out fuse is good Johnoolo Acura Integra 2 01-14-2014 01:24 PM
2007 Fit M/T Remote start install tleatham Audio / Security / Video 14 06-28-2012 02:49 AM
tach installment sam0218 Honda CRX / EF Civic (1988 - 1991) 12 01-15-2007 08:46 PM
Civic Dash Lights!!!! Vtec77 Honda Civic / Del Sol (1992 - 2000) 7 05-27-2005 08:29 AM
instrument lights and dimmer not working. Tetronious Honda Civic / Del Sol (1992 - 2000) 0 11-26-2003 08:04 PM
Tags
1992, 1999, box, dash, del, ej6, ek, fuse, fusebox, guide, integra, label, panel, sol, underdash
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
