Type r swap in eg???
OK guys so i bought an eg and it came with a b18c5 swap but no wiring harness my question is can i use a gsr or eg harness harness or would i have to use the type r harness please help any info will help.
i know if i want to bar i would have to use a obd2 harness!
also would i have to run the type r swap obd2 or can i run obd1 since its a obd1 chassis for bar purposes?
#1 Super Guy
Re: Type r swap in eg???
I can't comment on BAR, but I can tell you that an OBD2 engine harness would make it plug & play. I'm using an US OBD2 GSR harness on my 94 Civic w/ 97 JDM B18C Type R swap. I had to modify the harness for the EVAP purge solenoid because the pins are different for the GSR. I think I had to combine one wire from the IAB and one wire from the GSR EVAP to make the OBD-1 EVAP work.
It does depend on what ECU your going to run. A chipped P28 (or converted P05) would be best as you won't have to worry about wiring up the knock sensor. Just get one with a really good base-map for your motor from a place like pherable.net. They can even convert your stock ECU (weather P05 or P28) if you can send it in to them. If you've got a VX, you will need a different ECU as people won't modify them.
If you need to pass BAR, you better go talk with them first before you do anything. They will tell you exactly what you need to do so you can pass. I know a lot of times you need to convert everything on the JDM motor to US spec (which is very costly). That is if they still let you do JDM swaps at all.
killaberna
27
08-26-2014 06:44 PM
blackbndt
10-08-2009 06:00 PM
g356gear
08-11-2008 09:41 PM
