Turn signals do not work but the flashers do. - Honda-Tech
Old 09-05-2011, 11:52 AM   #1
Default Turn signals do not work but the flashers do.
So like the title states my turn signals do not work but when I use the emergency flashers both of them work. All the fuses have been replaced with new ones so I'm not sure where the problem lies. I'm thinking it has to do with the wiring. If anyone knows what to do or where a wiring diagram is at it'd be much appreciated. Also I'm not sure if this is related but my reverse lights do not work either and the bulbs have been replaced with new ones. So any help would be great Thanks.
nitro911 is offline   Reply With Quote
Old 09-05-2011, 12:26 PM   #2
riceordie's Avatar
Default Re: Turn signals do not work but the flashers do.
Check your wiring and also check to make sure your lever for turning your turn signals on is hooked up correctly
riceordie is offline   Reply With Quote
Old 09-05-2011, 12:29 PM   #3
Quote:
All the other lights work, and all the fuses are new and working as stated.
Old 09-05-2011, 03:52 PM   #4
bump
Old 09-05-2011, 04:22 PM   #5
If you hope to get useful replies, then provide all pertinent information about your car and engine:
Former User is offline   Reply With Quote
Old 09-06-2011, 11:07 AM   #6
JDM8o9's Avatar
flasher relay
JDM8o9 is offline   Reply With Quote
Old 09-06-2011, 11:48 AM   #7
Quote:
Originally Posted by JDM8o9 View Post
flasher relay
If this were true, neither the blinkers or hazards would work, right?
Old 09-07-2011, 12:58 AM   #8
I would assume so. But my hazard lights do work and all fuses have been replaced with new ones. So I'm thinking a short somewhere then? I don't know though.
Old 09-07-2011, 02:28 AM   #9
kyosoeg6's Avatar
i have a feeling the plug or clip just behind the steering wheel is loose but not to a point to where u can see it. unplug it and plug it back in. see if that does anything
kyosoeg6 is offline   Reply With Quote
Old 09-07-2011, 03:38 AM   #10
make sure ur connection by the plugs are good they tend to short out on eks alot i have took a couple extra harness's from junk yards because mine have been starting to pull apart on me.
apexi_rsx is offline   Reply With Quote
5th Gen Turn Signal Flasher Fix BigRonDawg Honda Prelude 1 10-20-2016 08:38 PM
Bizarre Flasher Problem 02 Civic EX technotrevor Honda Civic (2001 - 2005) 3 02-17-2016 02:44 PM
Turn signal relay verses flasher???? Phrog Honda Civic / Del Sol (1992 - 2000) 6 01-31-2014 02:12 PM
Turn Signal Flasher Location Gordi2 Honda Accord (1990 - 2002) 6 04-29-2005 08:07 AM
Flasher Module Location jverr Honda Accord (1990 - 2002) 0 08-09-2004 09:42 AM
Tags
1996, blinker, blinkers, civic, dont, ep3, flashers, honda, integra, lights, make, signals, turn, ur, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
