turn signals blink fast
Re: turn signals blink fast (trinaryt)
Are you sure one of the bulbs aren't out. When one of the bulbs go out the blinker will blink fast. If both are good, then maybe the previous owner was running smaller bulbs causing it to blink faster. Replace them with the normal size bulbs.
If not, pull the corners and look closely at the ground wire going into the bulb harness on both sides. The guy I bought one of my hatches from cut the ground on both the bulb harness' to give the 'tweaker blinker' effect. Splice'em back together and u'r golden!
One of three things could've happened:
1.) He may have gheytto rigged the rapid blinkers by snipping the black ground wires off each corner socket.
2.) Different spec bulbs
3.) Replaced the OEM signal relay (control unit next to your underdash fuse box) with an aftermarket one.
W95civicEXcoupe
03-05-2015 02:51 PM
Bambooseven
03-03-2009 08:40 PM
