TURBO SCREEN/FILTER/PIPING FOR 2000 SI
Hey guys i have a 2000 si with a low boost setup...i believe i need to have a filter for the turbo which i dont as it can suck up a stone/pebble/sand i will b working directly on the beach soon so i need some form of protection but i dont have a lot of space because the fan is the way..what are the suggestions....such as piping and type of filter to use?? and will i lose power as a result?? thanks guys!!
1 Post
Re: TURBO SCREEN/FILTER/PIPING FOR 2000 SI
loose 2-5% power vs blowing up your engine? i would use chicken wire or window mesh around under compressor housing with a clamp... SEARCH(google) IS YOUR FRIEND
http://www.google.com/imgres?q=diy+t...W1r2lDw&zoom=1
as far as the fan being in the way, i know they have slim fans that will create more room and maybe you'd be able to fit a better filter on there then. do some research.
well i've been doing some research...but will that fan be efficient?? will it cover the whole surface area? don't have any over-heating problems don't wana create one...i was thinking of custom building a pipe then placing that filter to the extreme left infront the coolant reservoir.....and what filter would the best to use??
https://honda-tech.com/forums/showth...=1433&t=729316
scroll down about 1/4 of the way. i would do something like that. not sure on the brand of filter though. spectre?
