Ecu help
Ecu help
I recently changed out my motor in my 94' del sol si with the d series vtec and put a JDM b16 in it. the motor is running well, but vtec is giving me problems does anyone know all the pinouts that need to be changed and/or added sense i am using the d series wiring harness on the car. I know the Knock sensor, and i heard about putting the IAT sensor into a17 oinout. Is this all true, if so how the IAT sensor is a two wire plug which one goes in which?
Re: Ecu help (mongoliandonuts)
there is no changes if you are running the same P28 as you used otherwise be prepared to add knock sensor if running P30 ECU.
thanks Katman , again for the visual aids.
ps. search before posting.
WOODman
10-07-2005 07:09 PM
