what clusters fit 2000 si?
Old 07-06-2011, 04:09 PM
jumpin4abeat's Avatar
Default what clusters fit 2000 si?
So I think my cluster is bad because when i disconnect the vss the speedometer stays at 20mph, connected or not. I changed the vss thinking that was the problem but i think its the cluster since it does not change if disconnected. I was curious on what cluster will fit? Like a lx cluster, integra cluster?
Old 07-06-2011, 04:16 PM
hyperblu's Avatar
Default Re: what clusters fit 2000 si?
Si,SiR,Spoon,Mugen,any ek cluster... crv clusters are interchangable i believe also....
Old 07-06-2011, 05:02 PM
are there any integra clusters that will fit?
Old 07-06-2011, 05:05 PM
hyperblu's Avatar
with some modifications...
Old 07-06-2011, 05:37 PM
is there a way to just test my cluster to see if it is the cluster then before purchasing a new one? Everything works besides the speedometer. The cel came on before with code 17 and since i replaced the vss the cel has not come back but it is still not working on cluster. I figured since when i unplugged the vss and the cluster did not drop to 0 it has to be the cluster. Am i correct or could it be something else as well?
Old 07-06-2011, 07:08 PM
hyperblu's Avatar
Put it in another ek civic... I doubt its the cluster.
Old 07-06-2011, 07:25 PM
Crazy Honda Guy
Deetz's Avatar
Civic VTi
it's unique, and not common in north america
Old 07-06-2011, 07:35 PM
hyperblu's Avatar
Originally Posted by Deetz
Civic VTi
We dont go by that km/h crap.
It would just annoy me.
Old 07-06-2011, 07:49 PM
pliskin8's Avatar
jaja!! so true
Old 07-06-2011, 08:44 PM
ev94eg's Avatar
try and see if the needle that goes through the mph is pushed to far in that happened to my cluster the gas stick was to far in and rubbing the surface of the cluster not letting it move
Old 07-07-2011, 02:45 AM
I know that it is not stuck just because when the car is turned off it sits at 0 but as soon as I turn key to on position if flips up to the 20mph mark.
What makes people think its not the cluster? What else could it be if I tested the harness and all voltage is good. Is there a way to run a seperate speedometer? Like put one in a pod or something? Its really annoying not knowing speed and I drive highway a lot which means Im not really going slow most of the time.
Old 07-07-2011, 07:36 AM
Crazy Honda Guy
Deetz's Avatar
Originally Posted by pliskin8
jaja!! so true
Next time you guys make comments like that, do some research, they were available in both formats
Old 07-07-2011, 07:51 AM
no one wants to hear the truth
cetcivic's Avatar
Your only options would be: spoon or mugen ek clusters...pick 1
Old 07-07-2011, 07:53 AM
kaiba's Avatar
Any year model Civic 96-00 and/or CRV 95-01.
Old 07-07-2011, 09:06 AM
sw388's Avatar
Just ask a friend (with an EK or CRV 95-01) as kaiba stated to help you out and swap clusters to eliminate the cluster being an issue. If ur doin 45 mph in first gear ur **** may be *ucked!!!
Old 07-07-2011, 01:27 PM
Is there a way to put a speedometer in a pod though and just run through that? I dont know anyone with civic cluster only teg cluster. I didnt know if there is a way to test the cluster besides placing into another car.
Old 07-07-2011, 02:27 PM
Is it normal to disconnect the vss and the cluster still reads at the 20mph. I am clueless when it comes to electrical. I figured the code 17 meant the vss was bad so i replaced that. Anyone have any opinions on what to do? I did get a multimeter but i really dont know what to do. I did hold the middle pin on the harness and the right outter one and there was slight continuity. I dont know if that means there is a plice in the wiring or what. If so can I just follow the wires back to the ecu and run new wires directly to it?
Old 07-07-2011, 02:43 PM
kaiba's Avatar
Yes, it is. There are 3 screw behind the speedometer. +, - and speed signal.
Old 07-07-2011, 07:32 PM
ek4me96's Avatar
u can put an s2k cluster wit some modifications. looks very sexy
Old 07-07-2011, 07:43 PM
anstitute's Avatar
yup, these are direct fit. even a caveman could swap them no problemo
teggy's require some electrical, s2000s look great too if you're good at that stuff
Old 07-08-2011, 03:34 AM
what do i do with these screws? Would the speed signal cause my speedometer to stay at a constant speed no matter what? I also find it odd that I looked at my odometer and it has not changed. Would the odometer still change if the car speedo is not working?
Old 07-08-2011, 04:31 AM
H-T White Ops
NOFX's Avatar
All '96-'00 Civic/Orthia/1.6EL clusters, plus the '97-'01 CRV cluster are plug and play.
Never heard of a 1995 or 1996 USDM CRV.
Old 07-08-2011, 05:37 AM
kaiba's Avatar
Screw you, I just look it up on wiki.
steventrrr
09-26-2010 08:34 PM
20-EM2-05
Honda Civic (2001 - 2005)
08-20-2009 12:14 PM
areede
08-17-2009 04:49 PM
Quick Reply: what clusters fit 2000 si?
