trouble mounting my ASR rear 24mm sway bar on my 2000 civic si - Honda-Tech
Old 12-28-2007, 08:51 AM   #1
Tuner Eddy's Avatar
Default trouble mounting my ASR rear 24mm sway bar on my 2000 civic si
Alright fella's, I ordered my ASR 24mm sway bar from weaksauce a few weeks back and decided to put it on tonight. I noticed while trying to line the holes up with the "D" brackets that the holes for the bolts were covered by the bracket when one bolt would go in.
To try and make better sense of it, only one bolt on each side of the D bracket would line up, and the other hole would be covered by the bracket.
This frustrates me, because i remember asking Weaksauce on the phone if the ASR sway bar would work with my Carbing rear lower tie bar, and they were firm with their assurance that it would work.
So I am asking, do I need to have the ASR subframe brace in order to run the sway bar?
Tuner Eddy is offline   Reply With Quote
Old 12-28-2007, 08:58 AM   #2
feeldabazzgsr's Avatar
Default Re: trouble mounting my ASR rear 24mm sway bar on my 2000 civic si (Tuner Eddy)
I am pretty sure you might need ASR brace...are you sure you wanna install that gigantic bar without brace?...i think it would tear apart your subframe if you install it without brace
feeldabazzgsr is offline   Reply With Quote
Old 12-28-2007, 12:35 PM   #3
Tuner Eddy's Avatar
you have to have the subframe brace to run the bar. bout to order it.
Old 12-28-2007, 12:45 PM   #4
BlueIntegraBoy's Avatar
Definitely need one. If you were to somehow mount it, subframe tearout would occur the first time you try to test out the sway bar.
BlueIntegraBoy is offline   Reply With Quote
Old 12-28-2007, 01:42 PM   #5
C-West Civic's Avatar
Pics??? I just did the ASR brace with a Cusco 24mm rear sway and it went on fine.
C-West Civic is offline   Reply With Quote
Old 12-28-2007, 01:52 PM   #6
Tuner Eddy's Avatar
Default Re: (C-West Civic)
Quote:
you got pics of your setup? i dont have any.
Old 12-28-2007, 03:40 PM   #7
Default Re: (Tuner Eddy)
Lemme know where your having your problem at based off my photo.
Old 12-28-2007, 03:43 PM   #8
KBG Indey's Avatar
I think the problem he's having is that he has a cusco TIE BAR
and ASR SWAY BAR
Not the other way around, like you have =P
KBG Indey is offline   Reply With Quote
Old 12-28-2007, 03:48 PM   #9
Na cuz he is sayin that his D bracket is covering th other hole that it should mount up to.
Do you have the right size D brackets? You need the bushings and brackets from the ITR
Old 12-28-2007, 05:59 PM   #10
KBG Indey's Avatar
Sorry about that was thinking about endlinks, not d brackets.
type r sway bar on gen 3 integra battmancjz Acura Integra 7 04-14-2016 08:51 AM
How to: Install ASR subframe brace and ITR sway bar on DC2 Integra GagnarTheUnruly Acura Integra 82 02-11-2014 03:58 AM
EJ8 Rear Sway bar help 91EF919 Honda Civic / Del Sol (1992 - 2000) 0 07-10-2011 08:35 AM
Does the asr 24mm sway bar with brackets bolt onto function7's 96-00 subframe brace? jdmdohcek98 Suspension & Brakes 8 09-17-2010 12:35 PM
trouble mounting my ASR rear 24mm sway bar on my 2000 civic si Tuner Eddy Suspension & Brakes 12 12-28-2007 02:35 PM
Tags
00, 2000, 24mm, 98, aem, asr, bar, civic, cusco, install, installing, mount, rear, si, subframe, sway
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
