Transmission ground strap mount? - Honda-Tech
Old 12-02-2011, 03:24 PM   #1
Default Transmission ground strap mount?
Hey everyone, im in the process of switching all my motor mounts to innovatives. While going along trying to install the trans mount preping the area i disconnected the transmissions ground strap but the bolt snapped off in the small bracket that holds the strap in place. The bracket is held on by two 10 mm bolts. Any one have an idea of the part number of that bracket from honda? The car is a 95 civic si stock d16z6 im sorry ive tried searching but didn't get any good results... Id really appretiate any insight to this.
02arcticz is offline   Reply With Quote
Old 12-02-2011, 03:48 PM   #2
EJ8_Man's Avatar
Default Re: Transmission ground strap mount?
Hmm. I'd suggest going to a junk yard or a hardware store and finding a bolt. If it's a non-critical bolt - ie it only holds the ground wire, then I'd simply ground the wire to something else.
EJ8_Man is offline   Reply With Quote
Old 12-02-2011, 04:19 PM   #3
Yeah the bolt head snapped off and i tried hitting the end of it out with a punch but it wouldn't budge the bracket kinda got mangled to say the least ha. I know it isn't the end of the world but id just rather have the legit replacement otherwise i will most deff find an alternate grounding point thanks for the suggestion. So any one else know the part #?
Old 12-04-2011, 08:54 AM   #4
EJ8_Man's Avatar
Well if you want to keep it looking legit I'd suggest drilling out the bolt and tapping it to the next size up provided there is enough metal to do so.
Old 12-05-2011, 05:54 AM   #5
kyden is offline   Reply With Quote
Ground strap is fine for valve cover ground? ezcape Acura Integra 5 05-10-2011 11:52 PM
how are you mounting you harnesses? .adam. Drag Racing 15 02-24-2011 09:50 AM
quick gas tank strap question huge230 Honda Civic / Del Sol (1992 - 2000) 0 04-22-2007 10:44 AM
Dropping fuel tank, how many of you guys had to replace the straps? BlueShadow Honda CRX / EF Civic (1988 - 1991) 1 02-14-2005 03:19 PM
Ground strap broke last night, replaced it, now speedometer isn't working????? 90si-rex Honda CRX / EF Civic (1988 - 1991) 19 12-07-2004 03:14 AM
Tags
2006, 2009, cable, civic, ef, ground, grounding, honda, part, pilot, strap, tech, tranmission, transmission, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
