tranny seal leak on a gsr transmission
i have a gsr tranny on my del sol that been leaking from the passenger side, i already replace the seal numorous times, i know how to do it (seal flush with the tranny)ive used honda seals and cheapo seals and it still leaks...i did pop an axle out one time while going about 85mph n replaced the axle right after...could i have effd up something inside the tranny or what other possibilities are there?theres no cracks on there
Re: tranny seal leak on a gsr transmission
Seal leak for several reasons. Either its the wrong one for your Trans, its been damaged during install to the Trans or upon drive shaft install, or there is play in the diff bearings causing play in the shaft and damaging the seal
Old Fart
If so, I would check the axel, as it is was replaced, [what axel is it, make]?94
the axle was bought brand new from autozone, its an oem like one...ive never had problems with these....is there sposed to be any play when its in place nd car is jacked up in the air?
ive changed that seal about three times....the time is used the oem honda one it only leaked a little, when i changed it and used one from an autostore it started leaking way more
Old Fart
It would not be the first time that an "oem like one" or even an OEM Honda part was DOA.
But I agree with instructor74 and you, you did "pop" and axle doing 85, that can't be good for the differential.
Did you check the bearing before installing the new drive shaft and seal(s)??
Don't forget to check the driveshaft. 94
pnltnc
12-07-2004 01:51 PM
