Torque specs for the Harmonic Balancer. - Honda-Tech
Old 04-15-2009, 11:59 AM   #1
TravisCadello's Avatar
Default Torque specs for the Harmonic Balancer.
Ok, YES, i have serched. but I found 85ft pound and 130ft pounds and other people just say tighten it and the engine will tighten it as u drive. so i need a firm answer because i changed out my Block just because my other one came off and broke the threads.
Its the Big pulley. i need to know how to tight to put it. i tightened it real hard untill i felt my tranmition about to break with it in 5th gear and the brakes smashed. it this good enough or is it gunna come off down the road?
TravisCadello is offline   Reply With Quote
Old 04-15-2009, 12:00 PM   #2
Default Re: Torque specs for the Harmonic Balancer.
oh its a D15B block and Y8 head.
Old 04-15-2009, 12:08 PM   #3
New User
134 lbs and apply oil to the bolt threads
Eclivic is offline   Reply With Quote
Old 04-15-2009, 12:17 PM   #4
sde780's Avatar
It's fine the way you did it. I hand tightened mine, drove for a couple weeks and it's fine
sde780 is offline   Reply With Quote
Old 04-15-2009, 12:34 PM   #5
apply oil to the threads? for what is loctite better? i just put it on but if i need oil let me know ill take it back off. i have a impact wrech the size of my head and 50lbs !
Old 04-15-2009, 12:59 PM   #6
New User
oil is just to help heat resistance with 134 lbs
Old 04-15-2009, 01:18 PM   #7
Quote:
will i need to put some on or no?
Old 04-15-2009, 01:43 PM   #8
New User
if the bolt is already on then dont worrie about it
B18b Lifter Nuts PLEASE HELP 10psiLsEf2 All Motor / Naturally Aspirated 6 04-23-2011 08:02 AM
help replace flywheel how many pounds???? mario_pic Honda CRX / EF Civic (1988 - 1991) 4 01-09-2008 10:36 PM
How many ft lbs of torque for engine mount bolts? hu Honda Prelude 4 07-25-2006 10:57 PM
inch pounds vs foot pounds ???? boosted350z Forced Induction 5 11-30-2004 11:32 AM
tie rod end problem xlerate93 Honda Civic / Del Sol (1992 - 2000) 8 08-24-2003 06:54 PM
Tags
2001, 99, accord, balancer, blancer, bolt, civic, engine, harmonic, honda, prelude, specifications, specs, torque, torquing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
