torque spec for civic single cam oil pan?
Re: torque spec for civic single cam oil pan?
92-95 Oil Pan D15B7, D15B8, D15Z1 and D16Z6:
96-00 Oil Pan D16Y5, D16Y8, B16A2 and D16Y7 all use this method for torque:
What differs between the D16Y5/D16Y8 vs D16Y7/B16A2 is how much and where you put the gasket maker.
Protip: If the gasket protrudes out from in between the bottom of the oil pan and the block, the pan is on too tight.
I torqued mine down to 8.7 and it bent the pan, gasket pooched out, etc. I did this with 2 different pans, then on the 3rd one I tightened up the bolts enough so the gasket was not visible. Haven't had a drop leak since.
This is on a D15b7 so I can't comment on any other engine, this is simply my experience.
I did mine to 10 ft-lbs with an extension and it's been a champ since. (Extensions reduce torque).
If you were bending your pan, then it was waaaay higher than 9 ft-lbs.
I believe you need a new torque wrench or get yours calibrated, 8.7 ft-lbs is very little torque and would not bend the steel oil pan of the D15B7.
I'm going to agree with you on this one. That particular torque wrench (and the other ones they sell, why mince words) has various issues. Most of them stemming from the fact that HF tools are, by and large, pieces of ****.
The Grumpiest
This is most likely your problem.
I bough a T-wrench from Autozone a while back and now that summer's here and I want to build my spare block, I'm scared to use it. Just going to get a Snap-on for piece of mind.
Home use, probably 6 months to a year is a more typical wrench maintenance schedule.
