Tire rotation
Tire rotation
Hi. I have a 99 Honda Civic Sedan and I was wondering what is the recommended factory method of rotating tires? I don't have an Owner's manual to look it up.
Re: Tire rotation
Sedans FTW! lol
I have a 98' civic sedan and work at a tire company. It is recommended to rotate your tires every 3-4k miles ( Every oil change). IF your tires are directional then you can ONLY rotate front to rear, but if they are just a normal tread IMO i would rotate... L/F to R/R; R/F to L/R; and just rotate both rear tires straight up front L/R to L/F and R/R to R/F
I hope this helps
I hope this helps
Re: Tire rotation
Sedans FTW! lol
I hope this helps
I hope this helps
The Grumpiest
Re: Tire rotation
By the pattern on the tread mostly. Some, if not most or all, actually have an arrow on the sidewalls that tells you. I haven't committed that detail to memory though.
Re: Tire rotation
Re: Tire rotation
Sedans FTW! lol
I hope this helps
I hope this helps
Re: Tire rotation
check the threads of the tires
if they all point to one direction like an arrow ^ or \\\, you can rotate front to rear ONLY
for example (lol) you can do cross rotation
if the threads are like the ones below, front to rear rotate ONLY
if anything seems wrong with the explanation i made, please correct me.
Re: Tire rotation
https://www.manualslib.com/manual/71....html?page=316
Re: Tire rotation
If the tires are bald/ worn from camber wear don't move them to the front replace it! Some shops sell used tires if you want to go that rout they usually have like at least 75% and go for like $40 installed depending on the shop.
