Tips for frozen door lock...
Old 12-02-2008, 05:08 AM
marcs1337's Avatar
Default Tips for frozen door lock...
so this morning, i couldnt get my door to open on my 94 del sol...the temperature dropped really low last night and i hadnt driven my car since friday...
i hear this is a pretty common problem in the winter for older civics...
anyone have any tips to getting the lock to turn after it is frozen?
Old 12-02-2008, 05:11 AM
97civicdx's Avatar
Try the other door.
Get lock de icer
Old 12-02-2008, 05:17 AM
marcs1337's Avatar
i plan on picking up some lock de icer, but the situation i was in this morning there was none available...
i even tried heating my key with a lighter and it didnt work
Old 12-02-2008, 06:37 AM
KingKhong's Avatar
poor hot water from the sink onto the keyhole. I too have a 94 del sol and it did that last winter. hasn't happened yet this winter.
Old 12-02-2008, 06:41 AM
Mr.Chow's Avatar
crawl in through the trunk...oh wait ****...
Old 12-02-2008, 06:44 AM
KingKhong's Avatar
you gotta remember to shut the trunk while you're in it, or it will not work.
bullitz400's Avatar
heat gun
Old 12-02-2008, 07:08 AM
VTECcivicDOWORK's Avatar
take a lighter and put your key in the flame for 30 seconds or a minute. the key will kinda turn black but it whipes right off. once the key is really hot stick it in the lock and unlock the door. i read about it online and it worked for me.
Old 12-02-2008, 07:12 AM
marcs1337's Avatar
i hear the lighter trick works quite well...i tried it but my flame kept going out, it was windy
Old 12-02-2008, 08:28 AM
honda.lioness's Avatar
I would not pour hot water on the lock, because this will just add more water that can freeze lock parts. Try a hair dryer/heat gun, like the other person said. Then buy some "Lock-Ease" (a well-known graphite solution) and follow the directions on its lable. At some point consider removing the lock cylinder and cleaning all the muck out of it, then lubing it with spray-on silicone lubricant. The lock should work like new. Here are two good descriptions of disassembly:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/diy-fixing-doorlocks-open-any-key-2237857/
http://www.zeebuck.com/bimmers/tech/...doorlocks.html
doklo
04-06-2021 03:54 PM
marcs1337
01-06-2009 03:02 PM
devney
02-26-2008 10:00 AM
toben
02-24-2007 08:05 PM
Midori so sickkkkk
11-15-2006 10:06 PM
Quick Reply: Tips for frozen door lock...
