tint remover
Old 06-25-2007, 03:04 PM
Midori Green's Avatar
Default tint remover
what can i use to remove my tints?... they are all faded and stuff
Old 06-25-2007, 03:05 PM
Syndacate's Avatar
Some dick that owned my GTI before I bought it put tint on it and did a half-*** job of course, I was able to get it off w/ "sticky stuff remover" and a razor (like you'd use to scrape off an inspection sticker on a windshield).
Old 06-25-2007, 03:12 PM
Default Re: (Syndacate)
so i can get that remover at like home depot or some ****?
Old 06-25-2007, 03:39 PM
Trey6904's Avatar
Default Re: tint remover (Midori Green)
Spray soapy water on the tint, put a plastic garbage bag on it and let it bake on in the sun. Pull the bag off the adhesive comes with the tint and all.
Old 06-25-2007, 03:43 PM
sniggler316's Avatar
Default Re: tint remover (Trey6904)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trey6904 &raquo;</TD></TR><TR><TD CLASS="quote">Spray soapy water on the tint, put a plastic garbage bag on it and let it bake on in the sun. Pull the bag off the adhesive comes with the tint and all.</TD></TR></TABLE>
I'll have to try this
Old 06-25-2007, 03:53 PM
EM1_00Si's Avatar
Default Re: tint remover (sniggler316)
Take a razor and pull the tint off. Buy some off that adhesive remover from autozone or somethin and wipe it off to get off the left over residue. Assuming its not a hatchback the rear windshield will be a mother.
Old 06-25-2007, 04:02 PM
tha_badguy's Avatar
i've done it this way
& it was pretty easy
just use a window cleaner with ammonia in it
Old 06-25-2007, 04:53 PM
Default Re: tint remover (tha_badguy)
is the tint on the inside or outside?
Old 06-25-2007, 05:26 PM
Darth ModerVader
Padawan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Midori Green &raquo;</TD></TR><TR><TD CLASS="quote">is the tint on the inside or outside?</TD></TR></TABLE>
The film is on the inside of the glass.
http://www.tintdude.com/remove.html
Old 06-25-2007, 05:53 PM
Default Re: tint remover (Padawan)
i dont have time to do all that im just gonna take it to the local shop to get it removed
Old 06-25-2007, 06:22 PM
EM1_00Si's Avatar
It will take about an hour to get all the tint itself off. The residue will come off pretty easy if you use an adhesive remover. I used the "Bug and Tar remover" from autozone. But if you have more money than time go for it.
Old 06-25-2007, 06:25 PM
Syndacate's Avatar
Default Re: tint remover (EM1_00Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Midori Green &raquo;</TD></TR><TR><TD CLASS="quote">so i can get that remover at like home depot or some ****?</TD></TR></TABLE>
Yeah, I don't know where they sell 'em, I just use a regular razor blade, but every shop has 'em. I'm sure they're readily available.
Old 06-25-2007, 06:26 PM
WhiteOnRice's Avatar
Are you serious....
To OP, go to Walmart and get tint-off
Old 06-25-2007, 06:30 PM
94eh2's Avatar
Default Re: tint remover (WhiteOnRice)
razor and soapy water.....
Old 06-25-2007, 06:31 PM
Damon Reeves's Avatar
Heat gun and a razor.
Old 06-25-2007, 07:01 PM
EM1_00Si's Avatar
Default Re: tint remover (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
Haha that looks a lot better then when I duct taped a razor to a flathead.
Old 06-29-2007, 05:40 PM
damn i want to remove my tint... but every shop tells me that there is no way to remove rear tint without damaging the defrost lines... but i cant even see with the tints so i rather just take them off and not have a rear defrost
Old 06-29-2007, 05:51 PM
Darth ModerVader
Padawan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Midori Green &raquo;</TD></TR><TR><TD CLASS="quote">damn i want to remove my tint... but every shop tells me that there is no way to remove rear tint without damaging the defrost lines... but i cant even see with the tints so i rather just take them off and not have a rear defrost</TD></TR></TABLE>
It can certainly be removed. Most shops simply don't want to go through the trouble, especially if you won't be giving them the business of installing new film on the car.
Old 06-29-2007, 06:00 PM
yea i guess thats probably why... but i need it removed as fast as possible cuz i have to pass inspection this week
Old 06-29-2007, 06:10 PM
Darth ModerVader
Padawan's Avatar
If you follow the procedure in the link I provided, you shouldn't have a problem. It's not fun and it might take a while, but you should be able to get it done Even if you do end up with a damaged defroster, it's normally an easy and inexpensive fix that you can do yourself.
Old 06-29-2007, 06:27 PM
JShull's Avatar
If you scroll down there is a how-to in this link.
The remover that they talk about can be purchased at Advance Auto I know for sure.
http://www.gilafilms.com/Autom...eight
Old 06-29-2007, 06:32 PM
zerovandez's Avatar
This is hella easy. It's just a big sticker on your window. Find a corner on a window, slide a razor under it and peel slowly. Then spray soapy water and scrape window at a hard angle to rid of the sticky gunk.
Old 06-29-2007, 07:19 PM
B18bEG6ick's Avatar
Default Re: (zerovandez)
i agree with the heat gun and the razor. works wonders especially when its really hot outside. as for the back window just use a razor on a corner and then use the heat gun to peel it smoothly. i did this last week and none of my defroster stipes got damaged. good luck.
Old 06-29-2007, 07:21 PM
Default Re: (B18bEG6ick)
im not talking about any of the other windows.. i can remove those.. all im talking about is the rear window that has the defroster lines on it... i dont even wanna touch that thing because of the defrost lines
Old 06-30-2007, 08:08 AM
zerovandez's Avatar
well if you do manage to mess it up then radio shack sells those defroster repair things. I hear they work pretty well.
Quick Reply: tint remover
