Timing question for Z6 crank pulley. Ive searched and cant find an answer
Old 04-30-2012, 06:15 PM
taytay's Avatar
Default Timing question for Z6 crank pulley. Ive searched and cant find an answer
If anyone has an answer for this please let me know...ive searched through and through and cant find the direct answer im looking for.
Seems like most z6 crank pulleys have 4 marks...3 ignition marks for 14* 16* 18* and 1 sitting off by itself which is the mechanical timing mark. Well my crank pulley has 2(TWO) marks sitting off by themselves seperate from the 3 ignition marks. My question is does the pointer on the belt cover point to the left/right mark or in the middle of them? Any help will be appreciated.
Old 05-01-2012, 05:25 AM
taytay's Avatar
Default Re: Timing question for Z6 crank pulley. Ive searched and cant find an answer
Bump 200 views and no one has had this similar question? I can't be the only one!
Old 05-01-2012, 06:14 AM
Fester LOD's Avatar
just put your dipstick in the #1 cylinder and what till u feel it at tdc and that will do it
Old 05-01-2012, 06:19 AM
taytay's Avatar
I don't want to 'feel' where tdc is..I want it to be precise. Just looking for an answer to my specific question.
Old 05-01-2012, 06:22 AM
delsolo95's Avatar
look in the FAQ section? there is a write up on how to change water pump and timing belt for the d16z6
KeithsDAteg's Avatar
Just try what the man said, and see which mark it puts you closer to. Then if you so choose to use that mark then fine.
I haven't ever seen a pulley like you describe. Can you post a picture?
Old 05-01-2012, 06:36 AM
taytay's Avatar
Yes del solo I've looked in that faq, the car in said faq has only one slash near tdc position on crank pulley, mine has 2. Like I said, I've searched everywhere. Even downloaded service manual and the answer isn't in there
Yes keithsda ill post a pic when I get home, and I really don't want to do the dipstick method, I just nee someone with the answer to my question to shed some light on the subject
Old 05-01-2012, 06:46 AM
delsolo95's Avatar
here i took these pic from username californiadad
take off your crank pulley and plastic covers. match up the arrow from the oil pump with the crank sproket like so
Old 05-01-2012, 07:05 AM
taytay's Avatar
Lol smh..I know you're trying to help del solo but that's not what I'm looking for. Not looking for an alternate way of timing the motor. I just want to know which of the 2 marks on my crank pulley depicts tdc..that is my quesion.
Old 05-01-2012, 08:00 AM
delsolo95's Avatar
then you must have the wrong crank pulley. ive done numerous timing belt/waterpump jobs and no honda pre 92-95 has five marks on them. either you need a different pulley to set tdc, do what i posted pics of or do what the other guy said and put a dip stick in the #1 piston and see which 1 of the 2 lines on the crank pulley meets up with the arrow. easy
if you cant figure that out. take it to a shop
Old 05-01-2012, 08:05 AM
taytay's Avatar
Ill just wait for someone to post that has an answer to my question. Its the original pulley that came on the motor. And its not that I can't "figure out" how to do what u said..itss that I do not want to.
Old 05-01-2012, 08:09 AM
taytay's Avatar
Thanks for trying though
Old 05-01-2012, 08:11 AM
EK9
Dc4LsTeG's Avatar
Why don't you post a pic of yours, so everyone knows what your taking about
Old 05-01-2012, 08:13 AM
taytay's Avatar
I certainly will when I get home in a few hours
Old 05-01-2012, 01:30 PM
taytay's Avatar
here they are
Old 05-01-2012, 05:03 PM
Like I said before... I've personally never seen a pulley like that. (May not mean a whole lot)
So I guess you have rare crankshaft pulley. Now, if your main concern is setting the mechanical timing of your engine then pick one of the aforementioned methods and be done with it.
Good luck brother.
-Keith
Old 05-01-2012, 07:37 PM
delsolo95's Avatar
Good luck brother.
-Keith
X2
Old 05-11-2012, 02:46 PM
lazyxmofo's Avatar
i have the same pulley. did you figure out which line to use?
Old 05-11-2012, 03:00 PM
taytay's Avatar
Its the one closest to the firewall :thumbsup:
Old 05-11-2012, 04:45 PM
lazyxmofo's Avatar
cool...i had a good feeling it was that one lol. just wasn't sure
Old 05-11-2012, 07:08 PM
suno's Avatar
lazymofo comes out of nowhere and solves the problem #forums
Old 05-13-2012, 07:41 PM
lazyxmofo's Avatar
you trying to flame me? cause your looking dumb yourself. i was "asking" if he figured out which line to use. what did i solve? you should go back to school and learn how to read #ignorantpeople
Old 05-13-2012, 08:13 PM
strategy400's Avatar
http://www.amazon.com/Innovative-Pro.../dp/B002XMOMA2
Old 12-08-2012, 07:43 AM
Kast014's Avatar
Anyone know how to get ahold of suno^^^ noticed this was his last post
suje
14
02-22-2012 04:19 PM
90si-rex
09-20-2009 08:47 PM
Civic-Kids
03-12-2009 01:45 PM
Quick Reply: Timing question for Z6 crank pulley. Ive searched and cant find an answer
