Timing Prob
Old 07-27-2005, 04:25 PM
D15BHatchbackcivic's Avatar
Default Timing Prob
I have a 92 honda Civic VX hatch with D15B. I set everything up by the book. The Crank was on the Compr. Stroke. and the Cam was set at zero and the rotor button was on #1 spark plug. I have fire i have gas and it wont run nothing no sputter no backfire. I put new distr. cap rottor button wires spark plugs and Timing belt. The timing belt went out in it. No valves are bent.
Thanks........
Old 07-27-2005, 04:28 PM
JDM-97CX's Avatar
Default Re: Timing Prob (D15BHatchbackcivic)
Might sound stupid but are the plug wires in the correct order?
Check your fuses as well. Especially the PCM fuse. For some damn reason, somtimes when you lose the timing belt that fuse likes to blow.
Old 07-27-2005, 04:34 PM
Well there in the right place. What is the PCM may soud stupid but i dont know. also i had it running but it wasnt running right it was like it was 180 out. So i redid it all and i wont run. i ve redone it 4 times its got me mad
Old 07-27-2005, 04:35 PM
JDM-97CX's Avatar
That is very strange. Has the distributor been removed at all?
Old 07-28-2005, 08:34 AM
Default Re: Timing Prob (JDM-97CX)
yes i removed the distributor but it can only go back in one way. but i didnt take it off and leave it off i took it off then put it right back in
Old 07-28-2005, 08:42 AM
hatchi's Avatar
did you check fuses?? does it even crank?? check wiring
Old 07-28-2005, 09:13 AM
nitroeg's Avatar
Default Re: Timing Prob (hatchi)
are you sure is the timing
Old 07-28-2005, 09:56 AM
Default Re: Timing Prob (nitroeg)
no im not sure if its timing thats why i posted this yes i checked fuses and it will crank
Old 07-28-2005, 10:12 AM
memphosfinest's Avatar
theres two ways to install it,the rigth way and the wrong way so I would check that again
Old 07-28-2005, 10:15 AM
distrubutor!!
graevz
05-21-2016 03:02 PM
TheLukeMartinez
12
02-26-2014 07:46 PM
hatchyboy89
10
07-17-2012 02:19 PM
mwwtx
02-10-2010 04:26 PM
BB6racer
06-16-2005 12:04 PM
Quick Reply: Timing Prob
