Timing issue - Honda-Tech
Timing issue
Old 01-23-2014, 03:04 PM   #1
carlos8's Avatar
Default Timing issue
hi guys, have a little problem with my time the camshafts are on spot the crank at TDC with a long extension. All the marks I made previous to disassembly the rockers are in spot. But the car rev's like retard, put the Distributor all the way advanced and works better.
http://honda-tech.com/attachment.php...1&d=1390518069
forget to mention the car was acting this way before the rocker and exhaust cam swap. I did the swap because the cam and rockers have excessive wear and I think this can be related.
carlos8 is offline   Reply With Quote
Old 01-23-2014, 03:34 PM   #2
Intelligently Stupid
TomCat39's Avatar
Default Re: Timing issue
It looks like you have adjustable cam gears. If they were set for excessively worn parts, wouldn't that make fresh parts be close to a half a tooth off with the old position of the cam gears?
TomCat39 is offline   Reply With Quote
Old 01-23-2014, 03:43 PM   #3
carlos8's Avatar
probably if you left the old setting with new cams they where a little off. But since in didn't have other set of ITR cams, I put GSR ones with the gears dialed at zero.
I think this what you mean excuse if not.
Old 01-23-2014, 04:00 PM   #4
TomCat39's Avatar
Actually the more I thought about it, the more my thought doesn't seem to fit.
I was thinking the wear would change positioning of the cam shaft, but really it's only going to affect how far the valve opens, not when.
Ignore my comment, it's not relevant.
Old 01-23-2014, 05:45 PM   #5
Since the cams are adjustable, the real question is where are the cam lobes for #1 when the crank is at TDC on compression stroke. That will tell if the cams are out of adjustment.
Might be a good idea to check them at each of the 90 degree points as well.
belairbrian is offline   Reply With Quote
Old 01-26-2014, 01:41 PM   #6
carlos8's Avatar
hi, trying to solve this problem, put the timing light with the cams at zero and spot the crank mark perfect but the car rev slowly and chocking. Put the intake cam gear at 5* advanced and the engine rev's but it's off on the crank.
This engine always be at zero with the lines on spot the only I changed was the rocker arms which not affect time and a GSR exhaust cam instead of the ITR but line perfect.
http://honda-tech.com/attachment.php...1&d=1390772432
Old 01-26-2014, 02:15 PM   #7
tony_2018's Avatar
Camgear doesn't look align.
tony_2018 is offline   Reply With Quote
Old 01-26-2014, 02:48 PM   #8
carlos8's Avatar
Did you see them off? Please point me which of them to try and reset them.
Also if you see my first post second photo you can see how the lines are flush with the head. Maybe is the angle maybe me.
Old 01-26-2014, 05:23 PM   #9
tony_2018's Avatar
I can't see the exhaust cam but the intake cam doesn't look align. I'm judging it by the way the adjust space on each of the screws are not the same.
Old 01-26-2014, 05:55 PM   #10
carlos8's Avatar
oh ok, B series always are this way!! The exhaust cam looks more high then intake.
http://www.clubcivic.com/hatch/timing/cam-on.jpg
http://i41.tinypic.com/2jdhyeu.jpg
Old 01-27-2014, 08:23 AM   #11
carlos8's Avatar
After some research and talking with the guys of forced induction and drag.
They pointed me into check the cams grooves, keys and the gears key ways.
The Fidanza cam gears that actually I'm using have a lot side to side play with new keys. So ordered a new set of titanium GE gears, in hope this solve my problem.
Rod bearing clearence carlos8 Forced Induction 14 02-02-2016 07:55 AM
2000 Civic SI EM1 part out Quick Release Exhaust Mounts A/C P/S Hood Transmission etc nostreble Southern California (Sales) 3 12-28-2014 03:58 PM
B18b1 Timing light question. carlos8 Acura Integra 2 03-07-2014 07:23 AM
Degreaser did this to my engine! How to fix?? *PICS* Ju1cesk8er Honda Civic / Del Sol (1992 - 2000) 58 04-21-2012 02:09 PM
Does anybody know what rims these are? please help!!!!!! JLARA50 Wheel and Tire 1 01-25-2012 05:30 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
