Timing belt is off a tooth?
Old 08-30-2004, 07:27 AM
Jaydeep's Avatar
Default Timing belt is off a tooth?
How do I checked if the timing belt has skipped a tooth. I took off valve cover and plastic cover off. Picture will explain best if anyone has that.
Thanks guys
Old 08-30-2004, 08:24 AM
Eclpze97's Avatar
Default Re: Timing belt is off a tooth? (Jaydeep)
if its a b series im not sure but on a d series there are two marks on the cam gear that should be level with the top of the head and the cam gear should be pointinh up... and check for tdc then look on ur crank pulley, may need a light, then there are three white marks in a row l l l and then a red mark to the right like an inch and a half, the red mark should be lined up to a pionter on the timing belt cover, if those all line up your timing is correct.
Old 08-30-2004, 08:42 AM
hype r 555's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaydeep &raquo;</TD></TR><TR><TD CLASS="quote">How do I checked if the timing belt has skipped a tooth. I took off valve cover and plastic cover off. Picture will explain best if anyone has that.
Thanks guys</TD></TR></TABLE>
there will be two arrows on the cam gears one on each gear for b-series...., when the crank is at top dead center , each gear arrow should be pointing stright up , or in line with the arrows on the cylinder no. 1 cam bearings ...
using white out or a chalk crayon , mark the point on the timming belt where the arrow on the gear point to that will show you where the arrow is when viewing the motor from the top , if both marks do not line up with the indicator arrows on the cam bearings ,
i believe on the v-tec dogc. engines there is no arrow on the cam bearings but it should line up with the center of the cam rail !!!!
hope that helps
Old 08-30-2004, 09:59 AM
Jaydeep's Avatar
I got 2000 civic EX. So thats SOHC. When I check from top I saw two arrow pointing up. What else I need to check.
There were also white color stripe on belt. Do I need to check that?
Old 08-30-2004, 11:51 AM
Jaydeep's Avatar
anyone
Old 08-30-2004, 12:37 PM
B A N N E D
vtecb20coupe's Avatar
Default Re: Timing belt is off a tooth? (EeeJaySixxx)
did you try starting the car yet or were you just verifying before starting the car?
Old 08-30-2004, 01:12 PM
Jaydeep's Avatar
One side Timing belt is tight but other side is tittle loose. Is it normal?
My car is really sluggish thats the reason I wanted to check timing.
Modified by Jaydeep at 10:22 PM 8/30/2004
Old 08-30-2004, 04:27 PM
9civic7's Avatar
i just did the t-belt on my soch you want to have the up part of the pulley to be up and the the two marks on the cam gear to be lined up the the arrows on the pastic cover behind it then you want to line up the white mark on the crank pulley with the pointer on the lower timing cover
poormans_typer69
10-17-2007 07:32 PM
FOMULA91
04-28-2006 08:42 AM
honDA16
12-06-2004 06:03 PM
Honda Kustums
08-19-2003 06:36 PM
Quick Reply: Timing belt is off a tooth?
