Timing belt noises?
Timing belt noises?
I have heard that timing belts can make noise when they are too tight. Is this true? The reason I ask is my car has started making a new noise that is getting on my nerves. It seems like when it warms up it will make a damn sound like a toy car or something only under accleration not or barely noticable at idle. Also it whistles when speeding up to upshift every once in a while...Maybe its just the alternator belt of A/C belt..
How do you check to see if your belts are too tight?
Thanks
Thanks
Re: Timing belt noises? (flat-blk-HB)
My TB was too tight and it sounded like a supercharger (it made a weening noise when it accelerated). Try messing with the tensioner. It could also be your alternator or A/C which can also be easily adjusted. Sometimes cold weather causes the noises too.
Re: (1FastCoupe)
hmm i have that supercharger sound but i dont think its the belt. Im guessing its my LSD. How tight should the belt be then, maybe thats my problem also.
Re: (1FastCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1FastCoupe »</TD></TR><TR><TD CLASS="quote">does it sound like a pigeon got caught under the hood?</TD></TR></TABLE>
Yeah actually it does...
I am going to try to mess with it tomorrow.
Re: (flat-blk-HB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flat-blk-HB »</TD></TR><TR><TD CLASS="quote">
I am going to try to mess with it tomorrow.</TD></TR></TABLE>
The the belt is a little on the tight side. If you turn the crank counter clockwise with a 19mm wrench to TDC you should be able to twist the belt about half a turn on the exhaust side of the belt and almost half on the intake side...
NikeSB
09-14-2006 04:23 PM
bam181
08-20-2006 05:16 AM
ShaolinRider
09-24-2003 09:27 AM
