timing?
Old 08-25-2007, 06:56 AM
hondachris1994's Avatar
Default timing?
what happens when u advance the timing in a motor 2 much, other than detonation?
Modified by hondachris1994 at 3:16 AM 8/26/2007
Old 08-25-2007, 06:59 AM
hatchling37's Avatar
Default Re: timing? (hondachris1994)
Too much timing on what motor? N/A? Forced Induction? More timing allows for a more thorough burn for higher octane fuel.
Old 08-25-2007, 07:17 AM
Default Re: timing? (hatchling37)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchling37 &raquo;</TD></TR><TR><TD CLASS="quote">Too much timing on what motor? .</TD></TR></TABLE>N/A
Old 08-25-2007, 07:18 AM
If I put to much timing in a motor, doesnt detonation occur?
Old 08-25-2007, 07:43 AM
Ek Forever y0!
Libertariat's Avatar
Default Re: (hondachris1994)
How vague.
What is "too much." And in which direction?
Advancing timing is fine for cars with n/a setups that are less likely to knock/detonate.
There's no automatic answer. It varies per application/motor/setup/fuel
With boosted setups you usually retard timing to prevent knock/ping.
Old 08-25-2007, 07:59 AM
Default Re: (ek forever guy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">How vague.
With boosted setups you usually retard timing to prevent knock/ping.</TD></TR></TABLE>2 much advanced, my problem is when my car was tuned, the tuner had to put timing in the motor, well I recently put a new T-belt on the timing went back to where it was supposed to b, so now when I hit the gas hard it sounds like valve noise, but if I retard the timing the noise goes away...I was just wondering why to much timing causes the valve sounding noise?
Old 08-25-2007, 08:02 AM
Ek Forever y0!
http://auto.howstuffworks.com/ignition-system1.htm
Read it.
What are you doing going to a tuner or modifying your car when you don't know what changing the timing does?
And you don't "put on" timing, you either advance it, or retard it. Your engine ALWAYS has timing. It's not something you add.
Modified by ek forever guy at 10:46 AM 8/25/2007
Old 08-25-2007, 09:43 AM
Darth ModerVader
Padawan's Avatar
I'm really a bit confused about what your situation is here.
The basic answer is, yes, advancing the timing too much will result in detonation.
When you say your tuner had to "put timing in the motor", what exactly do you mean? How is the car tuned, and are you referring to him advancing the base timing at the distributor or playing with the timing maps in the ECU? It sounds as if you're talking about the base timing at the distributor. If so, what setting are you using?
Old 08-26-2007, 02:52 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">[url=http://auto.howstuffworks.com/ignition-system1.htm]
Modified by ek forever guy at 10:46 AM 8/25/2007</TD></TR></TABLE>I mean advancing it too much, btw good link <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">I'm really a bit confused about what your situation is here.
When you say your tuner had to "put timing in the motor", what exactly do you mean? How is the car tuned, and are you referring to him advancing the base timing at the distributor or playing with the timing maps in the ECU? It sounds as if you're talking about the base timing at the distributor. If so, what setting are you using? </TD></TR></TABLE>timing maps in the ecu not the distributor
Old 08-27-2007, 11:14 AM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondachris1994 &raquo;</TD></TR><TR><TD CLASS="quote">timing maps in the ecu not the distributor</TD></TR></TABLE>
base timing is set with the distributor
Old 08-27-2007, 11:55 AM
Darth ModerVader
Padawan's Avatar
How would you have altered the ECU's timing maps by changing the timing belt?
Old 08-27-2007, 12:56 PM
Default Re: (Padawan)
How would you have altered the ECU's timing maps by changing the timing belt? </TD></TR></TABLE>Im kinda clueless on that myself, when my tuner tuned the car we set the cams at tdc, and we were like 8 degrees out on timing, that was with the distributer all the way advanced, so he told me he could put timing in on the basemap, and he gave me a stock(b16 basemap) chip just incase the timing went back to normal, so when I changed my t-belt a month ago, I started the car up and when I took it for a test ride, the car was detonating bad
Old 08-27-2007, 12:59 PM
Darth ModerVader
Padawan's Avatar
Well either way, the only effect it would have had is on base timing (not the timing maps themselves), and that should not have changed either unless your timing belt was not installed correctly to begin with.
I put the b16 stock chip back in for a while, but yesterday I put the other chip back in and just retard the timing all the way back on the dizzy, and I have no detonation and the car runs like it did when it was first tuned
Old 08-27-2007, 01:02 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Well either way, the only effect it would have had is on base timing (not the timing maps themselves), and that should not have changed either unless your timing belt was not installed correctly to begin with. </TD></TR></TABLE>im thinkin when I bought the car it was installed correctly, cause when I installed the t-belt I put a screwdriver in the alignment holes of the cams to make sure they were tdc with the crank pulley
Old 08-27-2007, 01:57 PM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondachris1994 &raquo;</TD></TR><TR><TD CLASS="quote">I put the b16 stock chip back in for a while, but yesterday I put the other chip back in</TD></TR></TABLE>
Please elaborate.
You sound like your swapping sunglasses.
Old 08-27-2007, 02:00 PM
Please elaborate.
You sound like your swapping sunglasses.</TD></TR></TABLE>basically I had the b16 cjip with stock timing in, so I took it out and put the chip with timing back in
CIVIC96DXcp
04-19-2005 07:47 PM
platinum00
12-17-2004 08:53 AM
aron0903
08-04-2004 12:34 AM
VSM EXtasy
07-19-2003 10:19 AM
Quick Reply: timing?
