Tighten A/C belt for a 99-00 civic si
Old 10-01-2006, 04:33 PM
bzyrice's Avatar
Default Tighten A/C belt for a 99-00 civic si
So My cuz came over my house with his car we went out for a drive.. it was hot so he turned the a/c on .. the thing started to squeel. so i went under the driver side and pushed/pulled on the a.c belt to see if it was loose.. and it was.. never messed with the a/c belt before (my cars usually dont have a/c lol) . .
how do i tighten it? all kinds of stuff is in the way like the power steering.. etc.
Thanks!!
Old 10-01-2006, 05:29 PM
harley06's Avatar
Default Re: Tighten A/C belt for a 99-00 civic si (bzyrice)
also want to know!
Old 10-02-2006, 04:30 AM
bzyrice's Avatar
tttt
Old 10-02-2006, 04:31 AM
black_EM1's Avatar
Search?
Old 10-02-2006, 04:59 AM
bzyrice's Avatar
tried.. they all the same thing.. loosen a 14 mm bolt in the middle of one of the pulleys and tighten the screw.. but i tried to find the 14 mm bolt. and couldnt find one.. only a 19 mm bolt.. and i couldnt find the adjust bolt cuz the power steering is there..
Old 10-02-2006, 07:36 AM
Falqon's Avatar
Default Re: (bzyrice)
it's right below the power steering pump. You might need a flashlight to get a good look. I thought it was like 12mm, but I guess 14mm is possible. Anyway, you loosen the nut at the base and then use a 7mm wrench to turn the long threaded bolt that actually tightens the belt. Make sure you tighten the nut again, it WILL back itself off and make your belt loose again if you don't.
The entire procedure is a huge pain and I usually end up taking the ps pump and unbolting it and moving it toward the drivers fender as much as possible.
Disclaimer, this is how the 94 VTEC B16 a/c tensioner works, I am assuming the SI is the same. If necessary, just pull off the 4 bolts and move the a/c compressor out of the way, you should be able to get a good look at the tensioner.
Old 10-02-2006, 10:47 AM
bzyrice's Avatar
cool ill try
Old 10-02-2006, 11:09 AM
bzyrice's Avatar
btw u got any pics? and u dont have to loosen the actual pulley ? just have to adjust the tightening screw?
Old 10-02-2006, 02:48 PM
Falqon's Avatar
sounds like everythings loose enough, so no.
penultimeta
05-23-2010 03:31 PM
218luder
02-22-2009 06:57 PM
david76008
10-02-2008 09:01 PM
breezer69
12-31-2004 02:32 PM
Kavehman
08-14-2003 01:40 PM
Quick Reply: Tighten A/C belt for a 99-00 civic si
