THROTTLE BODY question!
I'm a Jackass
THROTTLE BODY question! (pics inside)
sup guys, I just got done doing a swap for one of my homeboys civic lastnight.. and everything went well... only small problem was that it is bogging on me! it bogs in the idle and lower rpms like 1or2... also if i let go of the gas in 1/2 gear it bogs..
I checked the 02 censor and it was fine, I replaced the sparkplugs and sparkplugs wires (whice needed to be changed anyways) I already checked the dissy and moved it and all that... and its still bogging.... timing is good, blets are new..
by the way I installed a D16y8 and i'm using a d16z6 Throttle Body... and i'm pretty sure thats the problem right there...
okay on to my question..
will s skunk2 TB fit on a stock y8 manny?
if so what size should i get? 60MM? 66MM? 68MM? 70MM ?
mods are I/H/E
Modified by -DesTiNy- at 11:33 AM 4/28/2006
Modified by -DesTiNy- at 12:37 PM 4/29/2006
mods are I/H/E
I'm a Jackass
Re: THROTTLE BODY question! (1cleangsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1cleangsr »</TD></TR><TR><TD CLASS="quote">Just wondering, is it throwing any codes? </TD></TR></TABLE>
nope,
omg, comon h-t HELP ME!
nope,
I'm a Jackass
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">Perhaps a dumb question, but have you tried adjusting the throttle cable and idle adjust screw?</TD></TR></TABLE>
where is the idle adjust screw???????????!!!!!!!!!!!! wtf! I did this whole swap... everything going great! you think its a leak??
I'm a Jackass
Re: (pdiggitydogg)
Circled in yellow, top of the TB. (I know its not the best picture, but you can see that its a screw head)
Depending on how "tight" it is, determines how much air is let in, at idle. Just open it up a bit.
thx!
hmmm... the more i open it the worse it bogs ?
wtf?!!! i dunno what to do!! i prolly gunna get a whole new TB
thx!
The iacv isnt going to stop bogging.
If turning the screw one way makes it bog worse, turn it the opposite way.
If it just wont work, you can always buy my y8 tb
Sixx23
02-12-2014 02:38 PM
twentytwocpb
03-20-2008 10:47 AM
Jdmbsixteen
17
02-18-2004 07:54 PM
