Thread Pitch of a Bolt. - Honda-Tech
Old 07-29-2011, 07:57 PM   #1
StreetRacinThug's Avatar
Default Thread Pitch of a Bolt.
I need the thread pitch size of the bolt that holds the knuckly to hub on a 1998 Honda Civic EX with Drum Brakes.
In the Rear its basic.
Rim, Drum, Shoes + Hardware. Wheel Hub with 32mm Axles Nut....After the hub comes off...is the part that bolts down to the Trailing Arm through 4 T45(think but definately torx) head bolts. And one 27mm Nut in the center. All these bolts are on the rear side of the Trailing Arm......I had to replace the whole trailing arm but keep my old Drum System and Hub assemebly. Unfortunatly due to age when the bolt was backed out....it somehow stripped it self. I unfortunately tried to screw it back on no luck. Im trying to find the size of the pitch thread of that bolt that has a 27mm Nut.
StreetRacinThug is offline   Reply With Quote
Old 07-29-2011, 08:33 PM   #2
Default Re: Thread Pitch of a Bolt.
Find the part diagram on majestic honda of the specific bolt you are looking for.
lordhelmet1584 is offline   Reply With Quote
Old 07-30-2011, 01:03 AM   #3
If it stripped out, you'll probably have to rethread it. It won't matter what it was, just get the next biggest size in a Grade 8 bolt. Don't even bother with metric, it's near impossible getting hardened metric hardware. I just had to order 2 LCA bolts from Honda along with a couple other things.
NotAJDMFanBoy is offline   Reply With Quote
96-00 civic rear LCA bolt size evosix Honda Civic / Del Sol (1992 - 2000) 3 07-31-2012 11:40 AM
New look on brake swap or bad idea? tumbleking Honda Civic / Del Sol (1992 - 2000) 36 07-22-2007 01:42 AM
Rear disc question SEARCHED trrbl1bmx Honda Civic / Del Sol (1992 - 2000) 9 12-07-2006 08:05 AM
trailing arm torx bolts vtecpoweredsol Honda Civic / Del Sol (1992 - 2000) 8 10-23-2005 07:20 PM
Bolt on Lower Control Arms The Poopsmith Acura Integra 3 09-05-2002 10:57 AM
Tags
2011, 27mm, axle, bolt, brake, civic, drum, honda, nut, pitch, removal, rethread, stripped, thread, threads
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
