thermostat stuck open, can i drive it without hurting it???? - Honda-Tech
Old 10-24-2006, 06:05 PM   #1
Default thermostat stuck open, can i drive it without hurting it????
00 civic si turbo, i just installed a new rad. fan and noticed that my temp gauge was staying at cold, i need to drive it 30 miles before repalcing the thermostat, is it fine????
1baddcivicsi is offline   Reply With Quote
Old 10-24-2006, 06:12 PM   #2
SOHC4life 96's Avatar
Default Re: thermostat stuck open, can i drive it without hurting it???? (1baddcivicsi)
Stuck open or stuck closed? Closed, no. Open, yes.
SOHC4life 96 is offline   Reply With Quote
Old 10-24-2006, 06:14 PM   #3
Default Re: thermostat stuck open, can i drive it without hurting it???? (SOHC4life 96)
open, the car wont heat up to operating temperature. so with a bad thermostat i cant see if my new fan works. so its ok to drive if its open???
Old 10-25-2006, 05:05 PM   #4
Brick Top's Avatar
Quote:
open, yes
Brick Top is offline   Reply With Quote
Old 10-25-2006, 05:10 PM   #5
chrisw85's Avatar
Open is fine as others have stated, the only thing is that since your car will not reach the ideal operating temp, (yes, you can overcool a car) your gas milage will take a hit becuase the ECU thinks the engine is still trying to warm up.
chrisw85 is offline   Reply With Quote
Old 10-25-2006, 05:15 PM   #6
Sleepy_Red_hatch's Avatar
Default Re: (chrisw85)
yes you can even run without a T-STAT, my bro did so for a year...but man was it ever a bitch getting heat during the winter
Sleepy_Red_hatch is offline   Reply With Quote
Old 10-25-2006, 06:24 PM   #7
EK45VTi's Avatar
Default Re: (Sleepy_Red_hatch)
my friend drove his car for 4.5 YEARS with stuck-open thermostat...
And the car is fine.... the only drawback is getting VTEC working on cold days cos when car finally warms up to an operating temperature, if you drive on the highway on low/mid range, the temperature GOES DOWN
And you can't use the heater in the cabin so you will probably catch a cold if you drive for a long time...
But 30 miles is nothing... just go for it, replace the t-stat and you're set
EK45VTi is offline   Reply With Quote
Old 10-25-2006, 08:03 PM   #8
SiYouLater's Avatar
Theres a company called Fail-Safe that makes thermostats to stay open if it fails.
SiYouLater is offline   Reply With Quote
Can i drive my 1996 civic without a thermostat? raider1qaz Honda Civic / Del Sol (1992 - 2000) 28 12-19-2016 08:20 AM
Car Overheating with thermostat but running fine without a thermostat Oscar Ponce Tech / Misc 1 02-27-2012 12:15 AM
Bad Thermostat 1998_4dr_gsr Acura Integra 7 06-16-2009 08:00 AM
wtt: Prelude Thermostat vinuneuro For Sale 1 02-26-2005 10:32 PM
Thermostat vinuneuro Honda Prelude 2 02-21-2005 09:21 PM
Tags
1990, 2002, accord, bad, car, civic, closed, drive, fail, honda, long, open, run, safe, stuck, thermostat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
