Is there any way to slow rust destruction?
Well I noticed that my 94 EJ Civic is rusting on the driver's side at the front-bottom of the wheel well and at the top of the wheel arch. It's just starting to break through the paint. Is there anything I can do for it to slow it down or stop it for a while before I can afford to have the whole area cut out and replaced? Would sanding the hell out of it and re-primering the area and trying to blend it back in help?
Any advice you could give is appreciated.
Thanks!,
zelifcam
Thanks!,
zelifcam
Re: Is there any way to slow rust destruction? (SpiritUnreal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpiritUnreal »</TD></TR><TR><TD CLASS="quote">Get a wire brush, and spend some quality time with your baby.
Then repaint the area. </TD></TR></TABLE>
Just start scraping it away until the metal is shiny, sand it, prime it, and paint it?
Re: Is there any way to slow rust destruction? (zelifcam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zelifcam »</TD></TR><TR><TD CLASS="quote">
Just start scraping it away until the metal is shiny, sand it, prime it, and paint it?</TD></TR></TABLE>
Yep. Or if it has rusted through put some more metal on there and the prime/paint. I would use naval jelly to dissolve the rust.
Re: Is there any way to slow rust destruction? (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
Yep. Or if it has rusted through put some more metal on there and the prime/paint. I would use naval jelly to dissolve the rust. </TD></TR></TABLE>
Naval jelly, what is that? That sounds like something I picked out of my belly button.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zelifcam »</TD></TR><TR><TD CLASS="quote">Naval jelly, what is that? That sounds like something I picked out of my belly button.</TD></TR></TABLE>
hahahahaha
hahahahaha
Re: Is there any way to slow rust destruction? (boredracer408)
These products are supposed to be pretty good...the por is actually something Ive seen used on cars. It will continue to harden over time...the more moisture in the air the better it works.
http://www.por15.com/
http://www.rustbullet.com/Application.htm
BTW that was about 45 seconds on Yahoo...sorry it took so long
