is there any way to bypass the vtec solenoid wiring in the ecu like the oil pressure switch? (search
Old 09-20-2004, 06:12 AM
JinDIESEL's Avatar
Default is there any way to bypass the vtec solenoid wiring in the ecu like the oil pressure switch? (search
chipped p28, jdm b16A engine.
i know that you splice D6 and A4 to bypass the oil pressure switch, but can you also bypass the VTEC solenoid wiring by splicing some wires in the ecu as well? or do i have no chance but to connect the wiring from the VTEC solenoid to the ecu? and where in the ecu do i connect it?
Old 09-20-2004, 07:48 AM
JinDIESEL's Avatar
Default Re: is there any way to bypass the vtec solenoid wiring in the ecu like the oil pressure switch? (se
bump
Old 09-20-2004, 07:51 AM
boomslang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JinDIESEL &raquo;</TD></TR><TR><TD CLASS="quote">can you also bypass the VTEC solenoid wiring by splicing some wires in the ecu as well? or do i have no chance but to connect the wiring from the VTEC solenoid to the ecu? and where in the ecu do i connect it?</TD></TR></TABLE>
No. You have to connect the vtec solenoid to the ecu to activate vtec. Pin A4.
Old 09-20-2004, 08:34 AM
JinDIESEL's Avatar
do i need to ground it too? or just to A4?
Old 09-20-2004, 09:38 AM
B_CRUZ!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JinDIESEL &raquo;</TD></TR><TR><TD CLASS="quote">do i need to ground it too? or just to A4?</TD></TR></TABLE>
no.
Old 09-27-2004, 02:19 PM
street dreams's Avatar
Location: chillin in that city called queen creek, but homes the atl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JinDIESEL &raquo;</TD></TR><TR><TD CLASS="quote">chipped p28, jdm b16A engine.
i know that you splice D6 and A4 to bypass the oil pressure switch, but can you also bypass the VTEC solenoid wiring by splicing some wires in the ecu as well? or do i have no chance but to connect the wiring from the VTEC solenoid to the ecu? and where in the ecu do i connect it?</TD></TR></TABLE>
what the hell does this work can u bypass the vtec oil pressure switch on the the vtec selinoid
Old 09-28-2004, 05:46 AM
JinDIESEL's Avatar
no u cant. my friend just connected the wiring from the vtec solenoid into A4 in the ecu. no more CEL for him.
tgjg19
08-17-2009 07:41 PM
tankizk
07-24-2007 10:36 PM
Firestarter
05-04-2006 05:35 PM
EgitR
04-07-2004 04:31 PM
Quick Reply: is there any way to bypass the vtec solenoid wiring in the ecu like the oil pressure switch? (search
