Are there any oil heaters that can run off 12v DC?
are there any heater pad element that can run off 12v DC? ok to use either cigarette lighter plug or wire up myself
the problem is that after parking the entire day in the freezing mountain, car will take at least 20 minutes for any heat to build up in the engine for driving/ heater. i want to run the heater pad during warm up minutes to speed up this process.(engine will be on so no worries about dead batteries). really need that heat faster to defrost the front windows and to get warm myself
there's also times when driving in the freezing mountain.. the engine eventually gets cold enough where the heater don't give out heat anymore, so i want to warm the engine a bit in those situation too. (yes thermostat is working. only does this went it's freezing temperature and driving for a while)
Re: oil heater
Get yourself one of these and change your thermostat.
http://cgi.ebay.com/NEW-Honda-Big-Re...item5add234c6b
I'm not Rick!
Re: oil heater
some kseries motors that were canada version had oil heaters on them for start up. im sure you could set up a switch to leave it on. you could always run the coolant a tad lower also.
Re: oil heater
Honda makes an engine block heater accessory. It screws into the block's coolant drainplug. What year/model Civic do you have?
1992-1995 install instructions
http://www.hondaautomotiveparts.com/.../16625_01.html
1996-2000 installation instrauctions
http://www.hondaautomotiveparts.com/.../19793_01.html
Re: oil heater
get a block heater and make an air deflector for your rad so it dosn't loose so much heat cardboard works good and its free. just don't block it off completly and keep an eye on your temp gauge
Re: oil heater
hmm the honda one uses AC power, is it possible to convert it to DC? i won't be at home when i use this, the car parks in the garage at home, it's for when i'm going out.
i'm fairly certain the thermostat is okie, because the temperature gauge always stays at middle even when the heater no longer provides heat, and it only happens in the low 30. If it's low 40s, the heater will still give out heat even if i'm on the freeway
Re: oil heater
Re: Are there any oil heaters that can run off 12v DC?
you could have a bad thermostat or something. It should work fine in 30 degree weather. I was expecting to hear something like -45 or something.
Seagull Management
Exactly, I regularly run my civic in -40 temperatures and even not using a block heater I have heat within 2 or 3 miles of driving.
Me too. Was driving my 98 Civic early this morning when outside air temps was 9F. Plenty of heat coming out the vents. Actually had to adjust the heat lever a little cooler because I was getting hot inside the car with the fan on high speed and the temp selector all the way over to the hot side.
I've driven my car in extreme sub zero temps plenty of times and I've never had a problem getting lots of heat out of the vents.
I don't know whats wrong, but it's not cold oil. As others have suggested, you have a blockage in the heater core or a faulty valve somewhere thats not letting engine coolant into the heater core.
I know for a fact that in stock configuration you should not be having heater problems even in temps down to -25F. I live in the Denver area and used to work in the mountains. Have driven tens of thousands of miles in sub-zero temps and never a problem with heat.
LL_SP4RROW
06-03-2011 10:00 AM
titi_vtec
12-21-2010 08:08 AM
12, 12v, 2001, acura, block, dc, engine, generate, heat, heater, installation, instructions, integra, oil, thermostat
