testing radiator fan
Re: testing radiator fan (pnltnc)
Do you mean just to see if it's getting power? Or isn't it kicking on while your driving? If your just seeing if it "works", I just ran a wire "extension" from the blue rad wire to the positive on the battery...What kind of car??
to test the fan, disconnect the relay and jump 2 points on the connector with a paper clip....to test the relay, disconect the plug from it and check for continuity (using a mulit-meter/DVOM) between the the 4 points on the relay itself.
See the Helms manual for the correct points to check cuz i dont remember the sequence's off the top of my head
hope this helps a little
mike
mike
big_jay239b16A
16
05-07-2015 03:31 PM
