98 EK GSR No start
Old 04-27-2012, 04:44 PM
Mr2Rotor's Avatar
Default 98 EK GSR No start
Ok I've been having an oil leak lately and I figured out it was the cam oil plug. So I replaced that but when I tried to start my car it wouldnt turn
So this is what's happening, I turn the key and the starter cranks for a split second and then it just spins freely. I replaced the starter and still the same thing I'm getting sparks, and I hear the fuel pump as well so those are out. I then had autozone test the starter and it was working perfectly fine.
Last thing I remember doing after everything was spraying brake cleaner to clean the oil off could this have affected anything?
Old 04-27-2012, 05:25 PM
ehrkeith's Avatar
Default Re: 98 EK GSR No start
Swap for known working starter, maybe a bad connection on the starter?
Check Power, Ground, and Signal. You may have knocked one of those loose when working on the car.
Old 04-27-2012, 05:30 PM
Zeusfire69's Avatar
Pull the starter off and look at the flywheel (specifically the ring gear) You may have teeth missing/damaged or it may have come loose from the flywheel itself and is just spinning on the flywheel (thus the sparking...)
Old 04-27-2012, 05:47 PM
Mr2Rotor's Avatar
I mean sparks in the plugs
Old 04-27-2012, 05:52 PM
Zeusfire69's Avatar
Oh...sorry,I thought you ment from the starter (most people would say "I'm getting spark" not sparks)...still...check the flywheel....it sounds like the starter is ok...
Old 04-28-2012, 12:27 PM
Mr2Rotor's Avatar
Took it to a shop and they told me my car wasn't making any compression at all WTF how does that happen by changing the cam oil seal plug?
Old 04-28-2012, 04:40 PM
Zeusfire69's Avatar
You arent making any sense...if the starter wont turn the motor over...there is no way you can do a compression test..? You have to be able to make the motor turn over...
Old 04-28-2012, 05:26 PM
Mr2Rotor's Avatar
Sorry the starter was actually turning it I just didn't notice due to the sound or feel. Any idea what could cause it to have no compression?
Old 04-28-2012, 05:52 PM
Zeusfire69's Avatar
Gotta go back to the basics...is the cam timing on? Did the belt slip a tooth..are the cams turning? Did the tensioner come loose? Gotta start there...this would surely cause no compression. Did you take anything apart that might make the belt come loose?
Old 04-28-2012, 05:59 PM
Mr2Rotor's Avatar
Nope only thing I changed was that little cam oil plug which just requires taking off the valve cover and the cam caps
Old 04-28-2012, 08:01 PM
beecee18's Avatar
My first thought is something done during the repair must have caused this,
But changing a cam seal, and 0 comp on all holes
just look back and try to make sure what and how was done that day, really weird.
Old 04-28-2012, 08:04 PM
beecee18's Avatar
keys in either the cams or most likely the crank pully missing the key and just spining, damaged keyway in the crank snub?????????
you just dont lose compression in 4 different holes like that unless cam/mechanical timing is well off, when you reset the belt make sure it was set to factory spec and not 180 off on the cams or crank.
Old 04-29-2012, 05:45 AM
Mr2Rotor's Avatar
Hmm does this help? When the car was turned off I had to hit the cap that was on the oil seal with a hammer a couple of times to get it off?
Old 04-29-2012, 06:09 AM
beecee18's Avatar
Completely irrelavent.
Do you have access to view the timing belt?, and if its on, do you know how to check for proper mechanical timing?
Old 04-29-2012, 07:36 AM
Mr2Rotor's Avatar
The mechanic checked the timing he said it was fine which is why he is stumped as to how I could have done it :/
Valve problem maybe?
Old 04-29-2012, 07:48 AM
beecee18's Avatar
It's hard to tell what your real problem is gonna be without physically seeing your rig, but I do know one thing, the valves will not develop a problem from just having the cam/camcap assy apart period.
If your problem arose right after the repair was attempted something was done wrong, or at some point of the reinstallation something is not kosher.
Unless it did run briefly long enough for you to go out and beat on it thus making the engine fail
Old 04-29-2012, 07:51 AM
beecee18's Avatar
With out being there physically I have to stick with the cam/cams and or crank being off 180 degrees, or just mechanical timing being off,
To be honest at least 1-2 of the holes should still hold at least a little compression
Old 04-29-2012, 01:22 PM
Mr2Rotor's Avatar
Well I found out I had bent valves it seems like my timing changed while I was working on it WTF? And when I cranked it the pistons slapped the valves :[
Old 04-30-2012, 06:02 AM
beecee18's Avatar
rebuild, learn, and move on,
glad to hear you got it figured out, get a used set of oem valves and a good cylinder head guy.
G60
10-13-2020 12:58 PM
Untouchable13
Honda Civic (2001 - 2005)
15
06-10-2009 01:55 PM
DC4 Rasta
08-29-2007 07:03 PM
RiCE On IcE 2
04-25-2005 10:17 AM
chhuong
08-13-2002 10:14 PM
Quick Reply: 98 EK GSR No start
